查看: 18477|回复: 53
[ebook] Getting Started with Simulink
发表于 2014-9-2 22:31:45 | 显示全部楼层 |阅读模式
Getting Started with Simulink  2013 ebook
Amazon link : http://www.amazon.com/Getting-Started-Simulink-Luca-Zamboni/dp/178217138X/ref=sr_1_1?s=books&ie=UTF8&qid=1409668485&sr=1-1&keywords=simulink
Get up and running with Simulink with this hands-on, easy-to-read guide
Overview
  • Dig deep into Simulink
  • No unnecessary theory - start modelling right away
  • Complex concepts made easy through examples
  • Packed with illustrations and detailed step-by-step walkthroughs
In Detail
Simulink is an engineer's Swiss army knife: instead of spending the day typing out complex formulas, Simulink enables you to both draw and execute them. Block after block, you can develop your ideas without struggling with obscure programming languages and you don't have to wait to debug your algorithm - just launch a simulation!
Getting Started with Simulink will give you comprehensive knowledge of Simulink's capabilities. From the humble constant block to the S-function block, you will have a clear understanding of what modelling really means, without feeling that something has been left out. By the time you close the book, you'll be able to further extend your modelling skills without any help.
We''ll start with a brief introduction, and immediately start placing the first blocks. Little by little, you'll build a car cruise controller model, followed by the mathematical model of a sports car in order to calibrate it. Then you'll learn how to interface your Simulink model with the external world. This book will give you an easy understanding of the tools Simulink offers you, guiding you through a complex exercise split into the three main phases of Simulink development: modelling, testing, and interfacing.
What you will learn from this book
  • Understand the pros and cons of Simulink
  • Describe your ideas using block diagrams
  • Tune your simulation parameters
  • Draw clean, uncluttered models by reusing the logic and subdividing it into inner blocks
  • Run simulations with the appropriate source blocks
  • Analyse the simulation results with the scope block
  • Implement S-functions to reuse legacy code
  • Interface Simulink with applications outside the MATLAB environment
178217138X_Simulin.pdf (1.96 MB , 下载次数: 505 )
发表于 2014-9-3 09:18:21 | 显示全部楼层
20132014
发表于 2014-9-9 15:56:24 | 显示全部楼层
下来看看,不知道有用没用
发表于 2014-9-10 10:45:40 | 显示全部楼层
发表于 2014-9-16 16:19:56 | 显示全部楼层
非常感谢楼主
发表于 2014-9-20 04:04:37 | 显示全部楼层
多谢楼主分享啊
发表于 2014-9-21 11:13:45 | 显示全部楼层
感谢楼主
发表于 2014-9-26 10:02:11 | 显示全部楼层
回复 1# 龚_利90
    学习一下,谢谢。
 楼主| 发表于 2014-9-30 09:51:08 | 显示全部楼层
回复 8# woodnevsay
You are welcome my friend
发表于 2014-10-1 21:53:20 | 显示全部楼层
感谢楼主
GMT+8, 2025-10-26 06:09 , Processed in 0.026775 second(s), 8 queries , Gzip On, Redis On.
