楼主: min4max
从Cadence官方网站下载安装Cadence所有软件!
发表于 2017-4-11 14:00:13 | 显示全部楼层
大神,我在运行cadence时报错如下:[1] 3588
# WARNING: HOST <andy-virtual-machine> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
virtuoso:   ERROR: The command /opt/cadence/IC617/share/oa/bin/sysname returned an error status:
                            unknown
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2017-4-13 09:06:50 | 显示全部楼层
现在cadence已经不能这么下载,Effective 9-Nov-2015, the access policy for software downloads has changed. Access is only available for our users registered with our support or B2B portals. If you are only registered on cadence.com you may not have access to our software downloads.
发表于 2017-5-6 16:04:46 | 显示全部楼层
回复 2# min4max
Thanks!
发表于 2017-5-18 16:08:01 | 显示全部楼层
楼主好人,感谢分享
发表于 2017-5-28 15:46:30 | 显示全部楼层
Thanks for your share.
发表于 2017-5-29 20:31:16 | 显示全部楼层
从Cadence官网直接下载安装
发表于 2017-6-13 15:56:36 | 显示全部楼层
仅注册已经不能再cadence官网下载软件了……………………
发表于 2017-6-26 21:06:23 | 显示全部楼层
靠谱。通用安装方法!~
发表于 2017-7-3 17:31:39 | 显示全部楼层
有没有人能够使用这种方法下载?
发表于 2017-7-18 21:00:18 | 显示全部楼层
谢谢楼主
GMT+8, 2025-12-28 22:04 , Processed in 0.018235 second(s), 3 queries , Gzip On, Redis On.
