查看: 3006|回复: 0
[求助] CCS3.3初始化出错
发表于 2014-5-21 09:24:08 | 显示全部楼层 |阅读模式
各位大虾,我用CCS3.3配置F2407启动时出现初始化错误的情况,请问怎么解决?
用2808的时候是正常的。
Error initializing emulator
I/O Port = 240
Board Name: F2407 XDS510 Emulator
Cpu Name: CPU_1
Abort:        Close Code Composer Studio.
Retry:        Try to initialize the emulator again.
Ignore:        Ignore the initialization error and start
        potentially without target debugging access.
Diagnostic:    Run diagnostic utility.
GMT+8, 2025-11-1 17:06 , Processed in 0.019777 second(s), 8 queries , Gzip On, Redis On.
