查看: 55076|回复: 154
[资料] Allen CMOS模拟集成电路设计第三版,CMOS Analog Circuit Design,Third Edition-2011
发表于 2014-4-13 11:32:04 | 显示全部楼层 |阅读模式
Allen写的CMOS Analog Circuit Design被成为模拟圣经,其第二版是于2002年出版发型的,而其最新版本Third Edition是2011出版的,附件正是该版本的电子版,特别说明该电子书没有加密,无水印,是可打印。
"CMOS Analog Circuit Design" provides beginning engineers with an overview of the principles and techniques for designing analog circuits to be implemented in CMOS technology. It combines the academic and practical viewpoints in an accessible and comprehensive text, suitable for upper level undergraduates and graduate students taking courses in analog electronics and analog design. 2.jpg
Chapter 1 - Introduction and Background
1.1 Analog Integrated Circuit Design
1.2 Notation, Symbology and Terminology
1.3 Analog Signal Processing
1.4 Example of Analog VLSI Mixed-Signal Circuit Design
Chapter 2 - CMOS Technology
2.1 Basic MOS Semiconductor Fabrication Processes
2.2 The PN Junction
2.3 The MOS Transistor
2.4 Passive Components
2.5 Other Considerations of CMOS Technology
Chapter 3 - CMOS Device Modeling
3.1 Simple MOS Large-Signal Model (SPICE LEVEL 1)
3.2 Other MOS Large-Signal Model Parameters
3.3 Small-Signal Model for the MOS Transistor
3.4 Computer Simulation Models
3.5 Subthreshold MOS Model
3.6 SPICE Simulation of MOS Circuits
Chapter 4 - Analog CMOS Subcircuits
4.1 MOS Switch
4.2 MOS Diode/Active Resistor
4.3 Current Sinks and Sources
4.4 Current Mirrors
4.5 Current and Voltage References
4.6 Bandgap Reference
Chapter 5 - CMOS Single Stage Amplifiers
5.1 Inverters
5.2 Differential Amplifiers
5.3 Cascode Amplifiers
5.4* Current Amplifiers
5.5* Output Amplifiers/Buffers
Chapter 6 - Simple Operational Amplifiers*
6.1 Design of CMOS Op Amps
6.2 Compensation of Op Amp
6.3 Design of Two-Stage Op Amps
6.4 Power-Supply Rejection Ratio of Two-Stage Op Amps
6.5 Cascode Op Amps
6.6 Simulation and Measurement of Op Amps
6.7 Macromodels for Op Amps
Chapter 7 - Complex Operational Amplifiers*
7.1 Buffered Op Amps
7.2 High-Speed/Frequency Op Amps
7.3 Differential-Output Op Amps
7.4 Micropower Op Amps
7.5 Low Noise Op Amps
7.6 Low Voltage Op Amps
Chapter 8 - Comparators
8.1 Characterization of a Comparator
8.2 Two-Stage, Open-Loop Comparator Design
8.3 Other Open-Loop Comparators
8.4 Improving the Performance of Open-Loop Comparators
8.5 Discrete-Time Comparators
8.6 High-Speed Comparators
Chapter 9 - Digital-Analog and Analog-Digital Converters
9.1 Introduction and Characterization of Digital-Analog Converters
9.2 Current, Voltage and Charge Scaling Digital-Analog Converters
9.3 Extending the Resolution of Parallel Digital-Analog Converters
9.4 Serial Digital-Analog Converters
9.5 Introduction and Characterization of Analog-Digital Converters
9.6 Serial Analog-Digital Converters
9.7 Medium Speed Analog-Digital Converters
9.8 High Speed Analog-Digital Converters
9.9 Oversampling Converters
Appendix A Circuit Analysis for Analog Circuit Design
Appendix B Integrated Circuit Layout
Appendix C CMOS Device Characterization
Appendix D Time and Frequency Domain Relationship for Second-Order Systems
Appendix E Switched Capacitor Circuits
发表于 2014-4-13 16:33:46 | 显示全部楼层
没有上传附件啊
 楼主| 发表于 2014-4-14 23:00:39 | 显示全部楼层
回复 2# cxytiger
这个帖子等待审核了,请参见:“[size=1.17em]Allen 模拟集成电路设计 第三版 CMOS Analog Circuit Design_3nd_2011”
   http://bbs.eetop.cn/thread-442310-1-1.html
发表于 2014-4-16 10:38:11 | 显示全部楼层
这个必须得下载
发表于 2014-6-18 01:02:47 | 显示全部楼层
Allen_CMOS Analog Circuit Design_3nd_2011
发表于 2014-6-26 21:17:11 | 显示全部楼层
你帖子前面有一个圆圆是什么啊?下载了你的附件谢谢偶
发表于 2014-9-17 20:39:48 | 显示全部楼层
zhege下载文件大吗???
发表于 2014-9-23 16:34:26 | 显示全部楼层
发表于 2014-10-31 11:09:37 | 显示全部楼层
[img][quote][/quote][/img]
发表于 2014-12-26 11:37:38 | 显示全部楼层
谢谢三楼所提供的好信息
GMT+8, 2025-9-17 05:42 , Processed in 0.222013 second(s), 6 queries , Gzip On, Redis On.
