查看: 1646|回复: 0
[招聘] Cadence北京招C++软件开发工程师
发表于 2014-3-4 17:01:49 | 显示全部楼层 |阅读模式
Beijing研发职位
工作地点:北京东城区北三环东路北京环球贸易中心
联系邮箱:cecilyl@cadence.com
1.
Senior/ Member of Technical Staff--- simulator front-end2 Vacancies
Position Description:
Research and design simulator front end
Position Requirements:
- Strong C++ programming and familiarity withdevelopment under Linux/Unix environment.
- Proficiency with linux/unix tools.
- Skills in one or more of script such as Python,Perl.
- Familiar with build and version-control systems.
- Good English communication skill both verbally andwriting.
- Good problem solving skill and team work spirit.
2.
Senior member of technical staff Virtuoso DesignEnvironment 1Vacancy
Custom digital and analog circuit designers mustgenerate and interpret large amounts of complex simulation data. Virtuoso ADEaccelerates design by enabling setup reuse, parallelizing and distributingcompute-intensive simulation, and through extensive post-processing andvisualization capabilities.
As an ADE programmer, you will:
-Work closely with simulation and visualizationteams in order to streamline tool flow and deliver new capabilities.
-Implement internal algorithms, provide APIs forother tools to integrate, and provide GUI support for the end user.
-Carefully consider data structures to handle largedata sets.
-Demonstrate strong OO knowledge using C++.
-Write tests to validate your implementation.
-Skilled in C++ programming, familiar withdevelopment under Linux/Unix environment;
-Familiarity with GUI development, especially usingthe Qt toolkit is a plus
-Familiarity with XML and/or SQL is a plus
-Be familiar with Analog-signal design is a plus;
-Good English communication skill both verbally andwriting;
-Good problem solving skill and team work spirit;
3.
Senior/Member of Technical Staff for RF simulator2 Vacancies
-The position is responsible for designing,implementing and maintaining Cadence Virtuoso platform for RF simulator. Theengineer will be responsible for leading multiple development efforts throughthe development process, and working with a cross-functional team to ensure thesoftware is tested, integrated and documented.
- Skilled in C++ programming, familiar withdevelopment under Linux/Unix environment;
-Exposure to the Cadence Virtuoso environment
-Familiarity with Analog, RF or microwave design isa strong plus;
- Education Requirement: Master in EE, CS, orrelated.
-Experience with RF simulation methods, such asHarmonic Balance, Envelope and Shooting Newton
-Understanding of distributed network theory
-Background or coursework in RF/microwave circuits
4.  Lead/Senior PV Engineer for SPICE CircuitSimulator 1 Vacancy
-Plan and develop strategyto test SPICE simulators
-Develop procedures,testcases, and designs to test, troubleshoot, and debug to make sure theproducts are performing up to the specifications and upholding software qualitystandards.
-Work closely with a groupof professionals to enhance product quality.
-Develop Perl or Shellscripts to automate test procedures.
-MS/BS or above majored inMicroelectronics, EE, or relevant.
-Customer IC designexperience 1-2 years.
-Familiarity with CadenceVirtuoso environment or analog circuit simulation is a plus.
-Teamwork and goodcommunication skills.
-Good at both written andspoken English.
GMT+8, 2025-12-25 16:41 , Processed in 0.029240 second(s), 7 queries , Gzip On, Redis On.
