查看: 1868|回复: 2
[招聘] Cadence北京多个EDA软件开发/验证工程师
发表于 2014-2-21 10:57:03 | 显示全部楼层 |阅读模式
工作地点:北京东城区北三环东路北京环球贸易中心
联系邮箱:cecilyl@cadence.com
薪资区间:16w-35w/
1.        Senior/ Member of Technical Staff--- simulator front-end
Position Description:
        Research and design simulator front end
Position Requirements:
        Strong C++ programming and familiarity with development under Linux/Unix environment.
        Proficiency with linux/unix tools.
        Skills in one or more of script such as Python, Perl.
        Familiar with build and version-control systems.
        Good English communication skill both verbally and writing.
        Good problem solving skill and team work spirit.
2.        Senior member of technical staff Virtuoso Design Environment
Custom digital and analog circuit designers must generate and interpret large amounts of complex simulation data. Virtuoso ADE accelerates design by enabling setup reuse, parallelizing and distributing compute-intensive simulation, and through extensive post-processing and visualization capabilities.
        As an ADE programmer, you will:
        Work closely with simulation and visualization teams in order to streamline tool flow and deliver new capabilities.
        Implement internal algorithms, provide APIs for other tools to integrate, and provide GUI support for the end user.
        Carefully consider data structures to handle large data sets.
        Demonstrate strong OO knowledge using C++.
        Write tests to validate your implementation.
        Skilled in C++ programming, familiar with development under Linux/Unix environment;
        Familiarity with GUI development, especially using the Qt toolkit is a plus
        Familiarity with XML and/or SQL is a plus
        Be familiar with Analog-signal design is a plus;
        Good English communication skill both verbally and writing;
        Good problem solving skill and team work spirit;
3.        Senior/Member of Technical Staff for RF simulator
        The position is responsible for designing, implementing and maintaining Cadence Virtuoso platform for RF simulator. The engineer will be responsible for leading multiple development efforts through the development process, and working with a cross-functional team to ensure the software is tested, integrated and documented.
        Exposure to the Cadence Virtuoso environment
        Familiarity with Analog, RF or microwave design is a strong plus;
         Education Requirement: Master in EE, CS, or related.
        Experience with RF simulation methods, such as Harmonic Balance, Envelope and Shooting Newton
        Understanding of distributed network theory
        Background or coursework in RF/microwave circuits
4.  Senior/Member of technical staff-Fastspice
        This is a software engineer position for Cadence Spectre XPS product. Spectre XPS is a new fastSPICE simulator which delivers up to 10X faster simulation throughput, and has high visibility among the company.
        In this position you will need to design, implement and troubleshoot Spectre XPS.
        You will also need to understand customer requirements, define functional specifications, debug customer cases and investigate simulation algorithms.
        You should be able to work independently and communicate with colleagues and customers.
        MS majored in CS/EE or related, or BS with 3+ years of relevant experience.
        Strong C/C++ programming skills under Linux/Unix environment.
        Solid understanding of data structures and algorithms; understanding of graph and numerical algorithms is a plus.
        Knowledge on semiconductor devices and circuits and SPICE simulators is a strong plus.
        Good problem solving skills and strong desire to learn new techniques.
        Good English communication skills both verbally and writing and team working spirit.
5.  Lead/Senior PV Engineer for SPICE Circuit Simulator
        Plan and develop strategy to test SPICE simulators
        Develop procedures, testcases, and designs to test, troubleshoot, and debug to make sure the products are performing up to the specifications and upholding software quality standards.
        Work closely with a group of professionals to enhance product quality.
        Develop Perl or Shell scripts to automate test procedures.
        MS/BS or above majored in Microelectronics, EE, or relevant.
        Customer IC design experience 1-2 years.
        Familiarity with Cadence Virtuoso environment or analog circuit simulation is a plus.
        Teamwork and good communication skills.
        Good at both written and spoken English.
 楼主| 发表于 2014-2-27 10:03:00 | 显示全部楼层
持续招聘中,欢迎投递!
发表于 2015-9-10 16:32:05 | 显示全部楼层
good good
GMT+8, 2025-12-28 20:13 , Processed in 0.014856 second(s), 5 queries , Gzip On, Redis On.
