发表于 2015-11-10 20:39:11
显示全部楼层
用probe命令,详见说明书第93页:
Structure files provide all data from the structure at a single bias point. The log files provide
terminal characteristics for a set of bias points. Use the PROBE statement to combine these and
allow certain structural quantities to be saved at each bias point.
The PROBE statement allows you to specify quantities to be saved at given XY locations. You
can also save the maximum or minimum of certain quantities. The value from the PROBE at
each bias point in DC or timestep in transient mode is saved to the log file. The syntax:
PROBE NAME=mycarriers N.CONC X=1 Y=0.1
saves the electron concentration at (1, 0.1) for each solution in the log file. When TONYPLOT
displays the log file, the value will be labelled mycarriers. You can then plot mycarriers
versus terminal bias or current or other probed quantities.
Certain direction dependent quantities, such as electric field and mobility, can be probed. In
these cases, specify a direction for the vector quantity using the DIR parameter.
The PROBE statement provides the only way to extract the actual values of quantities, which
are calculated along the sides of each triangle in ATLAS. The PROBE statement actually stored
the triangle side value closest to the probed location, while taking into account the direction
for vector quantities. |
