查看: 18158|回复: 22
Remcom XFDTD 7.3.0.3 (XF7) Full-Wave Electromagnetic Analysis
发表于 2014-2-9 01:45:56 | 显示全部楼层 |阅读模式
Identical to Agilent EMPRO (easily fix too by the way).. but noticed it has less CAD XL8tr capabilities. Either Way.. here it is in case anyone wanted it.
http://thepiratebay.se/torrent/9528415/Remcom_XFDTD_7.3.0.3_%28XF7%29_Full-Wave_Electromagnetic_Analysis_%5Bc
Decompress .7z file . . install software and licensing. run program ... select license from Crogram Files(x86)Common FilesRemcomLicenselicense.lic ...  select for that window to not pop up every time software is executed. enjoy. Power, Speed, and Usability: Remcom's Market-leading EM SolverXFdtd Release 7 (XF7) is the market's most modern 3D electromagnetic simulation software for FDTD-based modeling and simulation. ItΓÇÖs tremendously fast by leveraging NVIDIAΓÇÖs most advanced CUDA-enabled GPUs. And itΓÇÖs easy to use and engineered to replicate real-world processes.Key benefits of XF7 3D Electromagnetic Simulation Software include:    XStream GPU Acceleration for CPUs and GPU clusters enables calculations to finish in minutes as compared to hours. Use XStream with the GPUs in a single computer or link multiple GPU clusters in parallel via MPI + GPU technology for massive EM calculations.    Unlimited Memory support for problems exceeding 60 GB and billions of cells.    External Queue Integration (EQI) allows XFdtd users in HPC environments to submit/queue their simulations directly to the compute cluster through the user interface.    XACT Accurate Cell Technology resolves the most intricate designs with fewer computational resources.    CAD Merge seamlessly integrates new versions of CAD and PCB designs into existing projects.    XTend Script Library automates modeling and design with pre-loaded, customizable scripts for creating custom features.    First 3D EM solver in the industry to run natively on Windows, Mac OS X, and Linux    Guided modeling processes, editable modeling history, ability to edit imported CAD files    Intelligent, ultra-fast meshing expedites previewing of finished meshes prior to simulation.    Dynamic and interactive graphing allows results to be viewed and automatically updated as data changes.    Customizable Results Browser with filtering and search tools
发表于 2014-2-9 10:39:03 | 显示全部楼层
你确定是7z格式 ? 为何无法解?
发表于 2014-2-9 10:39:57 | 显示全部楼层
回复 1# LiquidStranger
你确认是7z格式? 为何无法解?
 楼主| 发表于 2014-2-9 16:04:14 | 显示全部楼层
回复  LiquidStranger
你确认是7z格式? 为何无法解?
phoenixson 发表于 2014-2-9 10:39
    I'm using google translate so forgive me if I misinterpret what you are asking. I compressed the files into .7z because it provides the best compression when compared to others. you can use 7-zip to decompress it. I chose to compress the files instead of doing the individual files in a folder because the torrents kept becoming corrupted and would stop working. As for the content, I found the Remcom XFDTD install and patched the necessary files using FlexLM PubKey verify method so it will take anything for sign in license file. I built the license file based on flexlm diagnostics giving me the features. Edited the MSI installation and replaced the files and added the license to it. So everything is pre-fixed with no need to run a crack (I have already done so). Everything else is OEM and untouched.
I will say that Agilent EMPRO is just as easy to patch (as well as Systemview + Genesis + ADS) ... but Empro looks identical to XFDTD but had more project import options (HFSS for example).
Hopefully I answered your question.. if not, then let me know. I found EETOP when searching for info. I have been helped here before by forum posts and downloads so I felt I would give back. I will have new releases that are hard to come by. I am working on SiSoft QCD .. it is a bit different than most but Ill get it ;) . Ansys EM is my specialty. SiWave - Designer - HFSS
发表于 2014-2-11 09:42:48 | 显示全部楼层
回复 4# LiquidStranger
   Yeah, I understood what you said, but after I download the stuff, the file name is just like a hash, but the file's size is correct, so I renamed the extention to .7z , then decompressed it, but failed, it notified that it's a not a valid .7z file, Do I need to upgrade my 7z extractor ?   Thank you, You are a good man, A professional Engineer, Nice to Meet You.
发表于 2014-2-12 06:05:12 | 显示全部楼层
不能下载啊,楼主或楼上的能传到百度云或其它地方吗,私信给我也行,很需要
发表于 2014-2-16 23:16:48 | 显示全部楼层
File corrupt, can't un-7zip it. Don't waste your time.
 楼主| 发表于 2014-2-23 22:07:50 | 显示全部楼层
回复  LiquidStranger
   Yeah, I understood what you said, but after I download the stuff, the  ...
phoenixson 发表于 2014-2-11 09:42
Don't know why my uploads have been doing that. I have re upped it to another file sharing site. Feel free to upload them anywhere else to share to others.
part 1:
http://www37.zippyshare.com/v/7980055/file.html
part2:
http://www46.zippyshare.com/v/51157948/file.html
 楼主| 发表于 2014-2-23 22:09:25 | 显示全部楼层
xertin1234 发表于 2014-2-16 23:16
sorry .. re upped
part 1:
part2:
发表于 2014-2-24 14:12:06 | 显示全部楼层
没看到license啊
GMT+8, 2025-12-26 13:41 , Processed in 0.032234 second(s), 8 queries , Gzip On, Redis On.
