查看: 3623|回复: 8
[招聘] 招聘:资深系统工程师(AMOLED IC)/资深数字IC设计/资深模拟IC设计--成都
发表于 2014-1-21 17:11:12 | 显示全部楼层 |阅读模式
招聘:
1.资深系统工程师(AMOLED IC)--成都
-Experiences and knowledge in LCD display technology development is important
- Ph.D/ M.Ph/ M.Sc/ B.Sc in ElectronicsEngineering equivalent
- 3 years of experience in IC design
- 3 years of experience in one or more of thefollowing areas: touch controller IC, LCD display systems, mobile phone systems
- Familiar with SoC design, Verilog HDL, C /C++, Assembly, FPGA prototyping, DSP, RTL, DAC and ADC
- Candidates with substantial workingexperiences, including university research experiences, will be considered asSenior Engineer
工作职责:
Toperform IC system design and compile system specification
- To prepare FPGA prototype setup
- To conduct system validation
- To conduct silicon evaluation
- To invent and develop cutting-edge touchtechnology
- To debug and investigate during product developmentcycle
- To prepare and generate system architecturereport
2.Senior Digital Design Engineer
Responsibility
-Perform logic design, RTL coding, design verification, logic synthesis, DFT and static timing analysis
-Develop verification environment and coverage closure
-Support wafer level testing and silicon evaluation
Requirement
- Experiences and knowledge in LCD display technology development is important
- B.Sc or above in Electronic Engineering or equivalent. Applicants with postgraduate degree would be considered as an advantage
- 5 Years or above of solid experience in one or more of the following areas: Verilog-based logic design and synthesis, constrained random testbench with System Verilog & UVM, assertion based design verification or circuit-level SPICE simulations
- Knowledge of SoC and embedded system.
- Knowledge of scripting languages such as Perl, TCL and Make
- Candidate with less experience will be considered as Digital Design Engineer
3.Senior Analog Design Engineer
Responsibility
- Perform accuracy analog circuit design, schematic entry, and circuit simulation, including high speed drivers, high speed interface IP, low jitter PLL, PHY, etc.
- Perform mixed-signals integration, silicon evaluation, device and process developmental support,
- Layout supervision and design documentation.
Requirement
- M.Ph/M.Sc/B.Sc in Electronic Engineering or Computer Engineering or equivalent,
- At least 3 years of IC design experience. People with familiarities / knowledge in display driver development is high priority,
- Experience in designing any of the following Analog blocks: Bandgap, Linear Regulator/LDO, PWM/DC-DC converter, Op Amp, Error-Amplifiers, Buffer, Gate/Source Drivers, Comparators, Bias Circuits, UVLO, Thermal Shutdown, ADC/DAC, LED Driver and etc…
- Candidates with substantial relevant working experience will be considered as Senior Engineer in leadership roles.
注:以上职位都要有做过手机、平板等触控屏幕IC设计经验
工作地点:成都
薪水:18-25万/年(可面议)
欢迎各位大神自荐与推荐
联系mail:1410113043@qq.com  13908090394(tom)
发表于 2014-1-22 13:08:13 | 显示全部楼层
ding! chengdu有职位了
 楼主| 发表于 2014-1-23 10:01:05 | 显示全部楼层
看来只有年后才有人光顾了
 楼主| 发表于 2014-1-23 11:16:47 | 显示全部楼层
新职位欢迎咨询,来信必复.
 楼主| 发表于 2014-1-27 14:18:25 | 显示全部楼层
此职位一定要有触控屏IC方面的设计经验。感谢给我的关注和咨询,祝大家春节愉快!
发表于 2014-1-27 15:47:38 | 显示全部楼层
回复 5# gaojichutou
到底是做什么,PLL,接口 还是触摸屏?
 楼主| 发表于 2014-2-13 09:30:47 | 显示全部楼层
回复 6# longqingshan
   做触控屏
 楼主| 发表于 2014-2-13 09:31:42 | 显示全部楼层
职位继续招聘,欢迎咨询
 楼主| 发表于 2014-2-18 09:54:25 | 显示全部楼层
职位继续,一定要有触控屏方面的经验谢谢!
GMT+8, 2025-12-15 01:52 , Processed in 0.024304 second(s), 5 queries , Gzip On, Redis On.
