楼主: mabas.masood
RSoft Component suite 2013.12 license (linux)
发表于 2014-3-6 18:50:17 | 显示全部楼层
回复 1# mabas.masood
When I start LaserMOD in Rsoft Com. Suite, it will show the message:
Feature removed during Imreread, or wrong SERVER line hostid.
Feature: RSOFT_LMCAD
License path: 27000@localhost
FLEXnet Licensing error:-92.234
When I changed in line "export SNPSLMD_LICENSE_FILE=27000@localhost" to my local hostname "export SNPSLMD_LICENSE_FILE=27000@localhost.localhostdomain" it shows another message:
SNPSLMD_LICENSE_FILE is incorrectly set. It is currently set to 27000@localhost.localhostdomain, but must be set to port@localhost
What to do? (CentOS 6.5)
 楼主| 发表于 2014-3-6 22:16:03 | 显示全部楼层
回复 11# largaseal
    you must use new licgen
发表于 2014-3-7 15:23:14 | 显示全部楼层
回复 12# mabas.masood
    I have used licmaker from bingled ([url]http://bbs.eetop.cn/viewthread.php?tid=366602)[/url]  and your .src file and instructions, but errors still appears. This licmaker is for win, where can I find licmaker for linux OS? What I'm doing wrong?
发表于 2014-3-7 16:54:19 | 显示全部楼层
can any one help on this:
The Clustering Option and Optimization option is off!! any solution for that??
i tried the RSOFT_CLUSTER RSOFT_CLUSTER_DIRECT but no help!!
in tutorials --> MOST --> Simple _cluster.ind
 楼主| 发表于 2014-3-7 18:51:13 | 显示全部楼层
回复 13# largaseal
use wine for run licgen in linux
use this licgen
http://bbs.eetop.cn/viewthread.php?tid=387203&highlight=%2B
i use centos 6
发表于 2014-3-7 20:27:30 | 显示全部楼层
回复 15# mabas.masood
    Thank you for your answers, I'll write what happens.
发表于 2014-3-7 20:27:36 | 显示全部楼层
回复 15# mabas.masood
发表于 2014-3-7 20:31:32 | 显示全部楼层
回复 15# mabas.masood
    Thank you for your answers. I'll write what happens.
发表于 2014-3-7 20:33:51 | 显示全部楼层
回复 15# mabas.masood
    Thank you for your answers, I'll try.
发表于 2014-3-8 20:17:34 | 显示全部楼层
多谢大侠分享
GMT+8, 2025-11-22 13:15 , Processed in 0.019041 second(s), 3 queries , Gzip On, Redis On.
