查看: 4169|回复: 7
Where can I download Cadence Quickview?
发表于 2013-12-18 18:27:04 | 显示全部楼层 |阅读模式
Which is product catalog for Quickview (K2 viewer) from Cadence SoftLink?Thanks,
发表于 2013-12-19 09:37:17 | 显示全部楼层
回复 1# wilson168
    為何一定要  Quick viewer ??
能看GDS 的
GDS VIEWER 軟體還有其他很多阿
不過 能直接看CADENCE COMPOSER 軟體到沒有
否則還真希望 CADENCE 出 windows os  composer viewer ..
发表于 2013-12-19 14:04:16 | 显示全部楼层
Cadence quickView? Why don't you just create an account on sourcelink and
download averything you need ??
 楼主| 发表于 2013-12-19 16:46:33 | 显示全部楼层
回复 2# peterlin2010
Because, Quickview is upgraded from K2 viewer.It is so fast to check not only GDS but also mebes data.
 楼主| 发表于 2013-12-19 16:56:56 | 显示全部楼层
回复 4# wilson168
Yes, I have account of SourceLink.I need to know which exact product catalog for Quickview is.
(for example: IC615 for Composer & Virtuoso....)
发表于 2013-12-20 17:03:12 | 显示全部楼层
ah, i see. On sourcelink there is a search button as well
Quickview => PVE 111 or PVE121 .
good luck
 楼主| 发表于 2013-12-27 19:22:43 | 显示全部楼层
回复 6# pilou271
Thank you sir, I got the k2_viewer pve121.
发表于 2018-11-26 18:38:57 | 显示全部楼层
回复 1# wilson168
Hello,i'm seaching for JDV software,can you recommend it? Thanks!
GMT+8, 2025-12-30 08:04 , Processed in 0.026688 second(s), 5 queries , Gzip On, Redis On.
