查看: 1669|回复: 0
[招聘] Current product engineer 项目工程师 美资打印机 上海
发表于 2013-12-3 16:55:10 | 显示全部楼层 |阅读模式
Job description:
This is a hardware current productengineering position, under the LaserJet printing quality organization based inHewlett-Packard Shanghai.
You will mainly focus on theelectronics, the mainboard PCA part and touch screen interface boards, which isused in our LaserJet printers. You will be the first point of contact for fieldand customer warranty issues. Responsibilities include analyzing parts fromfield returns, investigating into specific causes for high failure rates,recommendation for a fix, which may result in a design change or componentchange. You will need to work with partners from US for regular technicaldiscussions; therefore a strong command of English is necessary. Hands onexperience is required, the engineer will have to conduct debug analysis forthe failed parts for issue troubleshooting. Everyone in the team is a qualitychampion, monitoring warranty rates from the customer/field for products owned.You will need to work with the customer/field to understand quality andwarranty issues, driving the investigation and issue resolution. In the earlyNPI stage, you will provide hardware performance feedbacks to the R&D team,such that quality issues seen in predecessor design can be eliminated.
You are also the EE expert,consulted and responsible for EE part changes and developing qualificationplans for the changes. You would need to work with the factories/manufacturingpartners in implementing changes, either directly or through an operationsengineer.
Besides an EE engineer, you willalso be expected to participate or lead in special warranty improvementinitiatives for the emerging geographies. You would need to plan and managespecial tests as needed to support continuous improvement and to further understandingof product performance.
Skill requirement:
Bachelor degree and above: EEpreferred. Candidates from other discipline will be considered if they havesignificant relevant work experience.
6 years+ working experience(Bachelor), 4+ years working experience (Master)
Previous working experience onPCA/PC motherboard a must, ability to understand PCA schematics for subsequenttroubleshooting is required. FPGA design or application experience desired.Experience with touch screen CGD designs/QA/manufacturing is required.
Experience working either in anODM/CM environment, or managing the ODM/CM is advantageous.
Good understanding of EMC tests.
Good command of English (CET-6).
Excellent troubleshooting andanalytical skills.
Good Excel, Word, Powerpoint knowledge.Plotting charts and diagrams, creating powerpoint for issue updates and writingprocedural documents.
如果对此职位感兴趣,请发送简历到celinechou@163.com,或者可MSN celinechou@163.com 咨询。
GMT+8, 2025-12-15 09:31 , Processed in 0.015403 second(s), 7 queries , Gzip On, Redis On.
