查看: 2079|回复: 0
[招聘] [社招全职] Marvell 急招后端工程师及软件工程师
发表于 2013-11-26 10:41:04 | 显示全部楼层 |阅读模式
If youhave any interest in the position, please send your bilingual resume as
attachments to
marvell.resume@gmail.com Subjectof your email should be “YourName_University_Applied Position Title”
1\Job Title: Physical Design Engineer
Department: COT PD-SH -MTSL
Job Description:
Physical Design Engineer will support physical design requirement of differentbusiness unit of Mavell, the main responsibility is:
physical implementation, including floorplan, power routing, placement, clocktree synthesis, timing closure, routing, si fixing, drc fixing, dfm ...etc
physical verification: including low power check, timing analysis, timing eco,xtalk analysis, power analysis, ESD analysis, EM analysis, drc check, lvscheck, ant check, erc check ...etc
tapeout: timing signoff, power signoff, design tapeout... etc
Qualification:
BS/MS in EE/CS required.
Some knowledge and some experience on process, parameters, synthesis, timinganalysis, placement, routing, CTS, SI, power calculation, custom layout, timinganalysis and DRC/LVS.
Familiar with Cadence, Synopsys, Mentor, Magma, Apache… EDA tools and designflow;
Familiar with Verilog HDL, Spice
Good programming skill. Capable of writing Tcl or Perl.
Self-motivated team worker, good verbal and written communication skills inEnglish
2\Job Title: Engineer, Senior ASIC Design
Department: Central Engineering
Job Description:
As a Digital design engineer, he/she will contribute to the overall SoCdevelopment and IP development for the micron-controller oriented SoC Productline, which includes block level micron-architecture design, RTL coding,Simulation, SoC top level integration, verification and chip bring-up.
Qualification:
•BS degree in Electrical Engineering +5 years experience (or MS + 3 years) orequivalent in hardware development and system architecture.
• Familiar with ASIC design methodologies and flows.
• Experience in the usage of state-of-the-art design tools.
• Proficient in behavioral and RTL coding, Verification. Verilog is preferred
• Experience in logic synthesis, timing closure.
• Experience in Design For Test.
• Knowledge of Low Power architecture and design practice is desirable.
• Strong verbal and written communication skills and proactive team-workspirit.
• Working understanding of various system interconnect protocols such as: AHB,AXI, OCP, APB, and their impact on IP development.
3/Job Title: Software developer for LinuxBSP and Android
Department: AP System Engineering
Description,
In this position, you will be working with the platform architects, technicalleaders and other developers to contribute to embedded Linux BSP/Android andplatform software development. You will be responsible for the detaileddevelopment specifications (example, component Low Level Design) and unit testplans, participating in BSP software implementation for handheld and/orcellular platforms and work with the validation team to ensure the product isthoroughly tested and meets established release criteria.
The candidate is expected to have below extra qualifications:
•Master in Electronic Engineering or Computer Science major or with relevantexperience.
•ARM or embedded experiences
•Strong programming and debugging skills in C/C++
•Linux Kernel/Driver development experiences
•Hardware debugging experience or board design experience is a plus
•Multimedia framework GStreamer, OpenMAX or DirectShow is a plus
•Fluent communication in both Mandarin and English is a plus.
4.Job Title: Software Engineer in Test
Description,
In the position, the candidate will be responsible for creating and executingthe test suite/cases, test tools, and automation system to assure the qualityof software platforms, which cover components from low level boot-loader,device driver, OS, middleware (multimedia and graphics), and up to high levelapplication framework (like Android), and Marvell proprietarycompiler/debugger/performance tools.
responsibilities:
• Identify the functionality, stability, performance and power quality criteriafor the whole system or individual components;
• Execute test suites to reach defined test coverage and debugging requirement.
qualifications:
• Programming skill in C, C++ and scripting language, i.e. Perl, python, is amust.
• Knowledge or working experience in projects similar to above projects ispreferred.
• Experience in general embedded software development/debugging/validation andits automation is a plus.
• Leadership experience in either software validation or development is a plus.
• Technical influence and interpersonal influence experience in multi-nationalcompany is a must. (English and Mandarin)
QQ:1552937745
MSN: domiliu0801@hotmail.com
更多Marvell招聘职位,请访问
http://marvell.cnstaff.com/
GMT+8, 2025-11-7 05:20 , Processed in 0.015063 second(s), 5 queries , Gzip On, Redis On.
