查看: 1548|回复: 0
[招聘] Marvell Physical Design Engineer
发表于 2013-9-24 13:59:59 | 显示全部楼层 |阅读模式
Job Title: Physical Design Engineer
Department: Switching
Requirement:
Three or more years ofhands-on experience in IC physical design, verification and tapeouts.
Proven track records ofworking independently on place-and-route project running andDRC/LVS/ERC/Antenna debugging skills
Experience with Magma orSynopsys place-and-route tool set and physical design project implementation.
Good programming skill.Capable of writing Tcl or Perl.
Familiar with synthesis,static timing analysis.
In-depth understandingof fabrication processing steps used in major fabrication industries.
Self-motivated teamworker, good verbal and written communication skills in English.
Technical and teamleadership proffered. Previous management experience highly desired.
Experience withsynthesis, DFT, and verification is preferred.
Please kindly send yourresume to marvellresume@126.com withthe subject ”Physical Design Engineer” if you are interested in the position.
GMT+8, 2025-12-24 00:46 , Processed in 0.018583 second(s), 7 queries , Gzip On, Redis On.
