查看: 1689|回复: 0
[招聘] Cadence SH 招聘Principal Product Engineer—DDR IP
发表于 2013-9-16 19:06:50 | 显示全部楼层 |阅读模式
Title: Principal Product Engineer—DDR IP
更多职位信息敬请关注Cadence公众微信平台:Cadence_Recruitment
If you have interest, PLS send your update CV to zhangyl@cadence.com
Position Description:
Cadence is looking for an individual to work in an established memory controller design IP team. The group provides configurable DDR memory controller and PHY IP for ASICs. The job will be mainly focused on providing technical support to customers, however there will be a variety of other engineering tasks that will allow the candidate to expand skills and responsibilities.
Provide technical support to customers for integration of IP into ASICs including:
- Debugging of customers’ simulation or silicon issues.
- Reviewing of customers’ integration of our IP.
- Reviewing static timing reports to assist with customers’ timing closure.
- Answering technical questions about IP operation.
- Train field engineers in IP operation.
- Interface with the R&D Team to bridge product improvements and resolve customer issues.
Position Requirements:
- Excellent oral and written communication.
- BS + 5 years of prior work-experience or MS + 2 years of prior work-experience
- All front-end skills – RTL design & verification in Verilog, synthesis, static-timing analysis, DFT
- Back-end skills – place & route, physical verification, timing closure
- Time management skills sufficient to balance multiple high-priority projects.
- Willingness to learn new skills and perform tasks that often go outside area of current expertise.
Additional Desirable Qualifications:
- Experience with Static Timing scripts and report analysis
- Familiarity with DDR memory operation, system applications, AXI, OCP, AHB
- Familiarity with Framemaker
- Scripting – in Perl, TCL, etc..
GMT+8, 2025-12-23 23:11 , Processed in 0.014771 second(s), 5 queries , Gzip On, Redis On.
