查看: 2192|回复: 1
[招聘] MCU design和verification
发表于 2013-9-13 12:15:55 | 显示全部楼层 |阅读模式
MCU design and verification engineer
CPU Verification
QQ: 983144394
Email: jj_seu@hi-talent.net
#1 Senior system design engineer
Job description:
The candidate will be responsible for:
l
Design and integration an AXI/AHB based system including host processor, DDR controller, SD/MMC, Display I/F and other peripherals., as a verification/demo platform for the in-house designed video IP’s;
l
Build up the simulation based environment for the system, for the functional verification;
l
Investigate and develop related drivers for the used IP’s in the system;
l
Use ISE/Vivado/Quart, implement the design to Altera/Xilinx FPGAs,
l
Work with SW engineer, to bring up system/OS on the FPGA prototyping board. Debug and resolve failures with Logic Analyzer and/or ChipScope/SignalTap;
Qualification:
l
BS with 5+ years or MS with 2+ years experiences in electronic engineering/micro-electronics;
l
Must be highly self-motivator and good team player;
l
Good understanding and hands-on experiences in SOC development and related methodology;
l
Solid skills in logic design with Verilog/VHDL, timing closure and analysis;
l
Familiar with FPGA implementation with ISE/Quartus and debugging;
l
Knowledge and hands-on experiences in at least 2 of the below fields are required;
n
AXI/AHB bus protocols;
n
Design or bring-up of DDR2/3 controller/PHY;
n
Display interfaces/protocols such as LVDS/HDMI;
n
SD/MMC controller;
n
NAND/NOR flush controller
#2. CPU Verification Intern
Job description:
The candidate will take part in verification for the in-house designed CPU/MCU, including:
l
Maintain and improve the verification environment and flow;
l
Make the test plan according to the design specification, and execute it with System verilog based coverage monitors/assertions;
l
Develop direct tests and constraint random tests;
l
Coverage data collection and analysis;
Qualification:
l
Graduate student who will graduate in 2015, major in electronic engineering/micro-electronics;
l
Must be highly self-motivated, eager to learn and accept new knowledge, a quick learner;
l
Could work at least 4 days every week;
l
Knowledge and understanding of computer architecture and micro-architecture of RISC processors
l
Familiar with front-end ASIC design flow and Verilog HDL;
l
Familiar or experiences in high-level verification methodology (VMM/UVM/OVM), and/or hardware verification language (SystemC/SystemVerilog) would be a great plus;
l
Experiences or skills in assembly programming, and using scripting languages (Perl/Tcl/Shell) for flow automation is a plus;
#3. (Senior) MCU design and verification engineer
Job description:
The candidate will be responsible for in-house micro-controller design and verfication, including:
l
Micro-architecture definition;
l
Logic implementation with Verilog HDL;
l
Functional verification and performance tuning;
l
Synthesis and timing closure;
l
l
Qualification:
l
l
l
Solid skills and rich experiences in logic design, synthesis and timing analysis;
l
Familiar with all front-end flows including LINT check, simulation, synthesis, STA, formal and power analysis, etc.;
l
Knowledge and experiences in Computer Architecture and RISC processor (ARM/MIPS/SPARC) micro-architecture, familiar with associated tool-chains such as compiler, assembler, debugger etc.;
l
Familiar with CABAC algorithm in video coding standard such like H.264/AVC and HEVC or hands-on engineering experiences in video codec development is a big plus;
发表于 2013-9-14 23:01:19 | 显示全部楼层
where is position located?
GMT+8, 2025-11-6 16:52 , Processed in 0.839527 second(s), 6 queries , Gzip On, Redis On.
