查看: 2387|回复: 4
[资料] 3GPP2的实用规范,珍藏版5
发表于 2013-9-8 21:14:14 | 显示全部楼层 |阅读模式
C.S0011-A_MS_Minimum_Performance_Spec.pdf (1.87 MB , 下载次数: 34 )
发表于 2013-9-9 08:09:19 | 显示全部楼层
kankan
发表于 2016-8-20 17:32:06 | 显示全部楼层
thanks for your great share!
发表于 2017-2-23 08:56:54 | 显示全部楼层
CONTENTS
i
1 NOTES .......................................................................................................................xxxv
2 NORMATIVE REFERENCES ......................................................................................xxxvii
3 1 INTRODUCTION..................................................................................................... 1-1
4 1.1 Scope ............................................................................................................... 1-1
5 1.2 Terms and Definitions....................................................................................... 1-1
6 1.3 Test Modes ..................................................................................................... 1-14
7 1.4 CDMA Equations ............................................................................................ 1-15
8 1.4.1 Transmit Power of the Base Station ........................................................... 1-15
9 1.4.2 Received Signal Strength for Mobile Station Not in Handoff ........................ 1-16
10 1.4.2.1 Single-Path Case ..................................................................................1-16
11 1.4.2.2 Two-Path Case .....................................................................................1-17
12 1.4.2.3 Three-Path Case...................................................................................1-18
13 1.4.3 Received Signal Strength for Mobile Station in Two-Way Handoff................ 1-18
14 1.5 Tolerances...................................................................................................... 1-19
15 1.5.1 CDMA System Parameter Tolerances ......................................................... 1-19
16 1.5.2 Measurement Tolerances........................................................................... 1-19
17 1.6 Test Requirements for Mobile Stations Supporting Analog Operation................ 1-19
18 1.6.1 Modulated Tone Frequency........................................................................ 1-19
19 2 STANDARD RADIATED EMISSIONS MEASUREMENT PROCEDURE ........................ 2-1
20 2.1 Standard Radiation Test Site............................................................................. 2-1
21 2.2 Search Antenna................................................................................................ 2-1
22 2.3 Field-Strength Measurement............................................................................. 2-2
23 2.4 Frequency Range of Measurements ................................................................... 2-2
24 2.5 Test Ranges...................................................................................................... 2-2
25 2.5.1 30-Meter Test Range ................................................................................... 2-2
26 2.5.2 3-Meter Test Range ..................................................................................... 2-3
27 2.6 Radiated Signal Measurement Procedures ......................................................... 2-3
28 3 CDMA RECEIVER MINIMUM STANDARDS.............................................................. 3-1
29 3.1 Frequency Coverage Requirements.................................................................... 3-1
30 3.1.1 Band Class 0 (800 MHz Band) ..................................................................... 3-1
31 3.1.2 Band Class 1 (1900 MHz Band) ................................................................... 3-4
3GPP2 C.S0011-A Ballot Resolution Version
CONTENTS
ii
1 3.1.3 Band Class 2 (TACS Band)...........................................................................3-7
2 3.1.4 Band Class 3 (JTACS Band).......................................................................3-10
3 3.1.5 Band Class 4 (Korean PCS Band) ...............................................................3-11
4 3.1.6 Band Class 5 (450 MHz Band)....................................................................3-13
5 3.1.7 Band Class 6 (2 GHz Band)........................................................................3-17
6 3.1.8 Band Class 7 (700 MHz Band)....................................................................3-18
7 3.1.9 Band Class 8 (1800 MHz Band)..................................................................3-20
8 3.1.10 Band Class 9 (900 MHz Band)....................................................................3-22
9 3.2 Acquisition Requirements................................................................................3-23
10 3.2.1 Idle Handoff Tests......................................................................................3-23
11 3.2.1.1 Idle Handoff in Non-Slotted Mode on the Paging Channel ...................... 3-23
12 3.2.1.1.1 Definition ........................................................................................3-24
13 3.2.1.1.2 Method of Measurement...................................................................3-24
14 3.2.1.1.3 Minimum Standard..........................................................................3-26
15 3.2.1.2 Idle Handoff in Slotted Mode on the Paging Channel ............................. 3-26
16 3.2.1.2.1 Definition ........................................................................................3-26
17 3.2.1.2.2 Method of Measurement...................................................................3-27
18 3.2.1.2.3 Minimum Standard..........................................................................3-28
19 3.2.1.3 Idle Handoff in Slotted Mode on the Forward Common Control
20 Channel............................................................................................... 3-28
21 3.2.1.3.1 Definition ........................................................................................3-29
22 3.2.1.3.2 Method of Measurement...................................................................3-29
23 3.2.1.3.3 Minimum Standard..........................................................................3-31
24 3.2.1.4 Idle Handoff to Another Frequency ....................................................... 3-31
25 3.2.1.4.1 Definition ........................................................................................3-31
26 3.2.1.4.2 Method of Measurement...................................................................3-31
27 3.2.1.4.3 Minimum Standard..........................................................................3-37
28 3.2.2 Soft Handoff Tests .....................................................................................3-37
29 3.2.2.1 Neighbor Set Pilot Detection and Incorrect Detection in Soft Handoff ..... 3-37
30 3.2.2.1.1 Definition ........................................................................................3-37
31 3.2.2.1.2 Method of Measurement...................................................................3-37
CONTENTS
iii
1 3.2.2.1.3 Minimum Standard ......................................................................... 3-40
2 3.2.2.2 Candidate Set Pilot Detection and Incorrect Detection in Soft
3 Handoff................................................................................................3-41
4 3.2.2.2.1 Definition........................................................................................ 3-41
5 3.2.2.2.2 Method of Measurement .................................................................. 3-41
6 3.2.2.2.3 Minimum Standard ......................................................................... 3-44
7 3.2.2.3 Active Set Pilot Loss Detection in Soft Handoff.......................................3-44
8 3.2.2.3.1 Definition........................................................................................ 3-44
9 3.2.2.3.2 Method of Measurement .................................................................. 3-45
10 3.2.2.3.3 Minimum Standard ......................................................................... 3-47
11 3.2.3 Access and Access Probe Handoff Tests ..................................................... 3-47
12 3.2.3.1 Access Probe Handoff ...........................................................................3-47
13 3.2.3.1.1 Definition........................................................................................ 3-47
14 3.2.3.1.2 Method of Measurement .................................................................. 3-48
15 3.2.3.1.3 Minimum Standard ......................................................................... 3-50
16 3.2.3.2 Access Handoff.....................................................................................3-51
17 3.2.3.2.1 Definition........................................................................................ 3-51
18 3.2.3.2.2 Method of Measurement .................................................................. 3-51
19 3.2.3.2.3 Minimum Standard ......................................................................... 3-53
20 3.2.4 Candidate Frequency Single Search........................................................... 3-54
21 3.2.4.1 Definition .............................................................................................3-54
22 3.2.4.2 Method of Measurement .......................................................................3-54
23 3.2.4.3 Minimum Standard ..............................................................................3-56
24 3.3 Forward Common Channel Demodulation Performance ................................... 3-56
25 3.3.1 Demodulation of Non-Slotted Mode Paging Channel ................................... 3-56
26 3.3.1.1 Definition .............................................................................................3-56
27 3.3.1.2 Method of Measurement .......................................................................3-57
28 3.3.1.3 Minimum Standard ..............................................................................3-57
29 3.3.2 Demodulation of Slotted Mode Paging Channel .......................................... 3-57
30 3.3.2.1 Definition .............................................................................................3-57
31 3.3.2.2 Method of Measurement .......................................................................3-58
CONTENTS
iv
1 3.3.2.3 Minimum Standard.............................................................................. 3-59
2 3.3.3 Demodulation of Broadcast Control Channel in AWGN Channel..................3-59
3 3.3.3.1 Definition............................................................................................. 3-59
4 3.3.3.2 Method of Measurement....................................................................... 3-60
5 3.3.3.3 Minimum Standard.............................................................................. 3-60
6 3.3.4 Demodulation of Broadcast Control Channel in Multipath Fading
7 Channel ....................................................................................................3-61
8 3.3.4.1 Definition............................................................................................. 3-61
9 3.3.4.2 Method of Measurement....................................................................... 3-61
10 3.3.4.3 Minimum Standard.............................................................................. 3-62
11 3.3.5 Demodulation of Forward Common Control Channel ..................................3-62
12 3.3.5.1 Definition............................................................................................. 3-62
13 3.3.5.2 Method of Measurement....................................................................... 3-62
14 3.3.5.3 Minimum Standard.............................................................................. 3-63
15 3.3.6 Demodulation of Common Assignment Channel and Reception of
16 Common Power Control Channel................................................................3-63
17 3.3.6.1 Definition............................................................................................. 3-63
18 3.3.6.2 Method of Measurement....................................................................... 3-64
19 3.3.6.3 Minimum Standard.............................................................................. 3-65
20 3.4 Forward Traffic Channel Demodulation Performance........................................3-66
21 3.4.1 Demodulation of Forward Traffic Channel in Additive White Gaussian
22 Noise.........................................................................................................3-66
23 3.4.1.1 Definition............................................................................................. 3-66
24 3.4.1.2 Method of Measurement....................................................................... 3-66
25 3.4.1.3 Minimum Standard.............................................................................. 3-67
26 3.4.2 Demodulation of Forward Traffic Channel in Multipath Fading Channel......3-67
27 3.4.2.1 Definition............................................................................................. 3-67
28 3.4.2.2 Method of Measurement....................................................................... 3-68
29 3.4.2.3 Minimum Standard.............................................................................. 3-68
30 3.4.3 Demodulation of Forward Traffic Channel During Soft Handoff ...................3-69
31 3.4.3.1 Definition............................................................................................. 3-69
32 3.4.3.2 Method of Measurement....................................................................... 3-69
CONTENTS
v
1 3.4.3.3 Minimum Standard ..............................................................................3-70
2 3.4.4 Decision of Power Control Bit for Channels Belonging to Different Power
3 Control Sets During Soft Handoff .............................................................. 3-70
4 3.4.4.1 Definition .............................................................................................3-70
5 3.4.4.2 Method of Measurement .......................................................................3-71
6 3.4.4.3 Minimum Standard ..............................................................................3-71
7 3.4.5 Decision of Power Control Bit for Channels Belonging to the Same Power
8 Control Set ............................................................................................... 3-72
9 3.4.5.1 Definition .............................................................................................3-72
10 3.4.5.2 Method of Measurement .......................................................................3-72
11 3.4.5.3 Minimum Standard ..............................................................................3-73
12 3.4.6 Demodulation of Power Control Subchannel During Soft Handoff ............... 3-73
13 3.4.6.1 Definition .............................................................................................3-73
14 3.4.6.2 Method of Measurement .......................................................................3-73
15 3.4.6.3 Minimum Standard ..............................................................................3-74
16 3.4.7 Demodulation of Forward Traffic Channel in Multipath Fading Channel
17 with Closed Loop Power Control (FPC_MODE = ë000í) ................................. 3-75
18 3.4.7.1 Definition .............................................................................................3-75
19 3.4.7.2 Method of Measurement .......................................................................3-75
20 3.4.7.3 Minimum Standard ..............................................................................3-76
21 3.4.8 Demodulation of Forward Traffic Channel in Multipath Fading Channel
22 with Closed Loop Power Control (FPC_MODE = ë010í) ................................. 3-76
23 3.4.8.1 Definition .............................................................................................3-76
24 3.4.8.2 Method of Measurement .......................................................................3-77
25 3.4.8.3 Minimum Standard ..............................................................................3-78
26 3.4.9 Demodulation of Forward Traffic Channel in Multipath Fading Channel
27 with Outer Loop Power Control and Closed Loop Power Control
28 (FPC_MODE = ë000í, ë001í and ë010í) .......................................................... 3-78
29 3.4.9.1 Definition .............................................................................................3-78
30 3.4.9.2 Method of Measurement .......................................................................3-78
31 3.4.9.3 Minimum Standard ..............................................................................3-79
CONTENTS
vi
1 3.4.10 Demodulation of Forward Traffic Channel in Multipath Fading Channel
2 with Closed Loop Power Control (FPC_MODE = ë000í) and Transmit
3 Diversity (OTD or STS)...............................................................................3-79
4 3.4.10.1 Definition............................................................................................. 3-79
5 3.4.10.2 Method of Measurement....................................................................... 3-79
6 3.4.10.3 Minimum Standard.............................................................................. 3-81
7 3.4.11 Demodulation of Forward Traffic Channel in Multipath Fading Channel
8 with Closed Loop Power Control (FPC_MODE = ë010í) and Transmit
9 Diversity (OTD or STS)...............................................................................3-81
10 3.4.11.1 Definition............................................................................................. 3-81
11 3.4.11.2 Method of Measurement....................................................................... 3-81
12 3.4.11.3 Minimum Standard.............................................................................. 3-82
13 3.4.12 Demodulation of Power Control Subchannel During Reverse Pilot
14 Channel Gating .........................................................................................3-82
15 3.4.12.1 Definition............................................................................................. 3-82
16 3.4.12.2 Method of Measurement....................................................................... 3-82
17 3.4.12.3 Minimum Standard.............................................................................. 3-83
18 3.4.13 Demodulation of Power Control Subchannel During Reverse
19 Fundamental Channel Gating ....................................................................3-83
20 3.4.13.1 Definition............................................................................................. 3-83
21 3.4.13.2 Method of Measurement....................................................................... 3-83
22 3.4.13.3 Minimum Standard.............................................................................. 3-84
23 3.5 Receiver Performance ......................................................................................3-84
24 3.5.1 Receiver Sensitivity and Dynamic Range ....................................................3-84
25 3.5.1.1 Definition............................................................................................. 3-84
26 3.5.1.2 Method of Measurement....................................................................... 3-84
27 3.5.1.3 Minimum Standard.............................................................................. 3-85
28 3.5.2 Single Tone Desensitization........................................................................3-85
29 3.5.2.1 Definition............................................................................................. 3-85
30 3.5.2.2 Method of Measurement....................................................................... 3-86
31 3.5.2.3 Minimum Standard.............................................................................. 3-88
32 3.5.3 Intermodulation Spurious Response Attenuation........................................3-88
33 3.5.3.1 Definition............................................................................................. 3-88
CONTENTS
vii
1 3.5.3.2 Method of Measurement .......................................................................3-88
2 3.5.3.3 Minimum Standard ..............................................................................3-92
3 3.5.4 Adjacent Channel Selectivity ..................................................................... 3-92
4 3.5.4.1 Definition .............................................................................................3-93
5 3.5.4.2 Method of Measurement .......................................................................3-93
6 3.5.4.3 Minimum Standard ..............................................................................3-94
7 3.5.5 Receiver Blocking Characteristics .............................................................. 3-94
8 3.5.5.1 Definition .............................................................................................3-95
9 3.5.5.2 Method of Measurement .......................................................................3-95
10 3.5.5.3 Minimum Standard ..............................................................................3-97
11 3.6 Limitations on Emissions................................................................................ 3-97
12 3.6.1 Conducted Spurious Emissions................................................................. 3-97
13 3.6.1.1 Definition .............................................................................................3-97
14 3.6.1.2 Method of Measurement .......................................................................3-97
15 3.6.1.3 Minimum Standard ..............................................................................3-97
16 3.6.2 Radiated Spurious Emissions.................................................................... 3-98
17 3.6.2.1 Definition .............................................................................................3-98
18 3.6.2.2 Method of Measurement .......................................................................3-98
19 3.6.2.3 Minimum Standard ..............................................................................3-98
20 3.7 Supervision ...................................................................................................3-100
21 3.7.1 Paging Channel........................................................................................3-100
22 3.7.1.1 Definition ...........................................................................................3-100
23 3.7.1.2 Method of Measurement .....................................................................3-100
24 3.7.1.3 Minimum Standard ............................................................................3-101
25 3.7.2 Forward Traffic Channel...........................................................................3-101
26 3.7.2.1 Definition ...........................................................................................3-101
27 3.7.2.2 Method of Measurement .....................................................................3-102
28 3.7.2.3 Minimum Standard ............................................................................3-103
29 4 CDMA TRANSMITTER MINIMUM STANDARDS........................................................ 4-1
30 4.1 Frequency Accuracy.......................................................................................... 4-1
31 4.1.1 Definition.................................................................................................... 4-1
CONTENTS
viii
1 4.1.2 Method of Measurement ..............................................................................4-1
2 4.1.3 Minimum Standard .....................................................................................4-1
3 4.2 Handoff.............................................................................................................4-1
4 4.2.1 CDMA to CDMA Hard Handoff......................................................................4-1
5 4.2.1.1 Definition...............................................................................................4-1
6 4.2.1.2 Method of Measurement.........................................................................4-2
7 4.2.1.3 Minimum Standard................................................................................4-3
8 4.2.2 Transmit Power after Hard Handoff ..............................................................4-3
9 4.2.2.1 Definition...............................................................................................4-3
10 4.2.2.2 Method of Measurement.........................................................................4-4
11 4.2.2.3 Minimum Standard................................................................................4-7
12 4.3 Modulation Requirements..................................................................................4-7
13 4.3.1 Time Reference ............................................................................................4-7
14 4.3.1.1 Definition...............................................................................................4-7
15 4.3.1.2 Method of Measurement.........................................................................4-8
16 4.3.1.3 Minimum Standard................................................................................4-9
17 4.3.2 Reverse Pilot Channel to Code Channel Time Tolerance ................................4-9
18 4.3.2.1 Definition...............................................................................................4-9
19 4.3.2.2 Method of Measurement.........................................................................4-9
20 4.3.2.3 Minimum Standard.............................................................................. 4-10
21 4.3.3 Reverse Pilot Channel to Code Channel Phase Tolerance.............................4-10
22 4.3.3.1 Definition............................................................................................. 4-10
23 4.3.3.2 Method of Measurement....................................................................... 4-10
24 4.3.3.3 Minimum Standard.............................................................................. 4-10
25 4.3.4 Waveform Quality and Frequency Accuracy................................................4-10
26 4.3.4.1 Definition............................................................................................. 4-10
27 4.3.4.2 Method of Measurement....................................................................... 4-11
28 4.3.4.3 Minimum Standard.............................................................................. 4-12
29 4.3.5 Code Domain Power...................................................................................4-12
30 4.3.5.1 Definition............................................................................................. 4-12
31 4.3.5.2 Method of Measurement....................................................................... 4-12
CONTENTS
ix
1 4.3.5.3 Minimum Standard ..............................................................................4-13
2 4.4 RF Output Power Requirements ...................................................................... 4-13
3 4.4.1 Range of Open Loop Output Power ............................................................ 4-13
4 4.4.1.1 Definition .............................................................................................4-13
5 4.4.1.2 Method of Measurement .......................................................................4-14
6 4.4.1.2.1 Access Channel............................................................................... 4-14
7 4.4.1.2.2 Spreading Rate 1 Enhanced Access Channel.................................... 4-16
8 4.4.1.2.3 Spreading Rate 3 Enhanced Access Channel.................................... 4-18
9 4.4.1.3 Minimum Standard ..............................................................................4-20
10 4.4.2 Time Response of Open Loop Power Control............................................... 4-23
11 4.4.2.1 Definition .............................................................................................4-23
12 4.4.2.2 Method of Measurement .......................................................................4-23
13 4.4.2.3 Minimum Standard ..............................................................................4-24
14 4.4.3 Access Probe Output Power ....................................................................... 4-25
15 4.4.3.1 Definition .............................................................................................4-25
16 4.4.3.2 Method of Measurement .......................................................................4-26
17 4.4.3.2.1 Access Channel Probe Acquisition.................................................... 4-26
18 4.4.3.2.2 Enhanced Access Channel Probe Acquisition ................................... 4-26
19 4.4.3.3 Minimum Standard ..............................................................................4-27
20 4.4.4 Range of Closed Loop Power Control .......................................................... 4-27
21 4.4.4.1 Definition .............................................................................................4-27
22 4.4.4.2 Method of Measurement .......................................................................4-28
23 4.4.4.3 Minimum Standard ..............................................................................4-29
24 4.4.5 Maximum RF Output Power ...................................................................... 4-31
25 4.4.5.1 Definition .............................................................................................4-31
26 4.4.5.2 Method of Measurement .......................................................................4-31
27 4.4.5.3 Minimum Standard ..............................................................................4-34
28 4.4.6 Minimum Controlled Output Power ........................................................... 4-36
29 4.4.6.1 Definition .............................................................................................4-36
30 4.4.6.2 Method of Measurement .......................................................................4-36
31 4.4.6.3 Minimum Standard ..............................................................................4-36
CONTENTS
1 4.4.7 Standby Output Power and Gated Output Power ........................................4-37
2 4.4.7.1 Definition............................................................................................. 4-37
3 4.4.7.2 Method of Measurement....................................................................... 4-37
4 4.4.7.3 Minimum Standard.............................................................................. 4-38
5 4.4.8 Power Up Function Output Power ..............................................................4-39
6 4.4.8.1 Definition............................................................................................. 4-39
7 4.4.8.2 Method of Measurement....................................................................... 4-40
8 4.4.8.3 Minimum Standard.............................................................................. 4-41
9 4.4.9 Code Channel to Reverse Pilot Channel Output Power Accuracy .................4-41
10 4.4.9.1 Definition............................................................................................. 4-41
11 4.4.9.2 Method of Measurement....................................................................... 4-42
12 4.4.9.2.1 Code Channel Output Power for the Enhanced Access Channel
13 Header, Enhanced Access Channel Data, and Reverse Common
14 Control Channel Data ......................................................................4-42
15 4.4.9.2.2 Code Channel Output Power for the Reverse Traffic Channel.............4-43
16 4.4.9.3 Minimum Standard.............................................................................. 4-45
17 4.4.10 Reverse Pilot Channel Transmit Phase Discontinuity ..................................4-47
18 4.4.10.1 Definition............................................................................................. 4-47
19 4.4.10.2 Method of Measurement....................................................................... 4-48
20 4.4.10.3 Minimum Standard.............................................................................. 4-49
21 4.4.11 Reverse Traffic Channel Output Power During Changes in Data Rate..........4-49
22 4.4.11.1 Definition............................................................................................. 4-49
23 4.4.11.2 Method of Measurement....................................................................... 4-50
24 4.4.11.3 Minimum Standard.............................................................................. 4-50
25 4.5 Limitations on Emissions ................................................................................4-51
26 4.5.1 Conducted Spurious Emissions..................................................................4-51
27 4.5.1.1 Definition............................................................................................. 4-51
28 4.5.1.2 Method of Measurement....................................................................... 4-51
29 4.5.1.3 Minimum Standard.............................................................................. 4-53
30 4.5.1.3.1 Spreading Rate 1 .............................................................................4-53
31 4.5.1.3.2 Spreading Rate 3 .............................................................................4-56
32 4.5.2 Radiated Spurious Emissions.....................................................................4-58
CONTENTS
xi
1 4.5.3 Occupied Bandwidth................................................................................. 4-58
2 4.5.3.1 Definition .............................................................................................4-58
3 4.5.3.2 Method of Measurement .......................................................................4-58
4 4.5.3.3 Minimum Standard ..............................................................................4-59
5 5 CDMA ENVIRONMENTAL REQUIREMENTS ............................................................ 5-1
6 5.1 Temperature and Power Supply Voltage............................................................. 5-1
7 5.1.1 Definition.................................................................................................... 5-1
8 5.1.2 Method of Measurement.............................................................................. 5-1
9 5.1.3 Minimum Standard..................................................................................... 5-2
10 5.2 High Humidity.................................................................................................. 5-2
11 5.2.1 Definition.................................................................................................... 5-2
12 5.2.2 Method of Measurement.............................................................................. 5-3
13 5.2.3 Minimum Standard..................................................................................... 5-3
14 5.3 Vibration Stability ............................................................................................ 5-3
15 5.3.1 Definition.................................................................................................... 5-3
16 5.3.2 Method of Measurement.............................................................................. 5-3
17 5.3.3 Minimum Standard..................................................................................... 5-3
18 5.4 Shock Stability ................................................................................................. 5-3
19 5.4.1 Definition.................................................................................................... 5-3
20 5.4.2 Method of Measurement.............................................................................. 5-3
21 5.4.3 Minimum Standard..................................................................................... 5-4
22 6 CDMA STANDARD TEST CONDITIONS ................................................................... 6-1
23 6.1 Standard Equipment ........................................................................................ 6-1
24 6.1.1 Basic Equipment......................................................................................... 6-1
25 6.1.2 Associated Equipment................................................................................. 6-1
26 6.2 Standard Environmental Test Conditions .......................................................... 6-1
27 6.3 Standard Conditions for the Primary Power Supply ........................................... 6-1
28 6.3.1 General....................................................................................................... 6-1
29 6.3.2 Standard DC Test Voltage from Accumulator Batteries................................. 6-1
30 6.3.3 Standard AC Voltage and Frequency............................................................ 6-2
31 6.4 Standard Test Equipment ................................................................................. 6-2
CONTENTS
xii
1 6.4.1 Standard Channel Simulator .......................................................................6-2
2 6.4.1.1 Channel Model Parameters.....................................................................6-2
3 6.4.1.2 Channel Model Parameter Conditions and Tolerances .............................6-4
4 6.4.1.3 Channel Simulator Configurations..........................................................6-5
5 6.4.2 Waveform Quality Measurement Equipment.................................................6-5
6 6.4.2.1 Rho Meter for Radio Configuration 1 and 2 .............................................6-5
7 6.4.2.2 Rho Meter for Radio Configuration 3 through 9.......................................6-7
8 6.4.2.2.1 The Ideal Composite Reference Signal.................................................6-7
9 6.4.2.2.2 The Transmitter Signal-Under-Test ....................................................6-8
10 6.4.2.2.3 Active Code-Channel Identification, Symbol Detection and
11 Parameter Estimation ........................................................................6-9
12 6.4.2.2.4 Rho (ρ).............................................................................................6-10
13 6.4.2.2.5 Code-domain Power (CDP)................................................................6-11
14 6.4.2.2.6 Power in Undesired Channels...........................................................6-12
15 6.4.2.2.7 Code Domain Time Offsets and Phase Offsets Relative to Reverse
16 Pilot Channel...................................................................................6-12
17 6.4.2.3 Code Domain Measurement Equipment Accuracy ................................. 6-13
18 6.4.3 Base Station Equipment ............................................................................6-13
19 6.4.3.1 Transmitter Equipment........................................................................ 6-13
20 6.4.3.2 Receiver Equipment ............................................................................. 6-15
21 6.4.3.3 Protocol Support .................................................................................. 6-15
22 6.4.3.4 Timing Signals ..................................................................................... 6-15
23 6.4.4 AWGN Generator .......................................................................................6-15
24 6.4.5 CW Generator............................................................................................6-16
25 6.4.6 Spectrum Analyzer ....................................................................................6-17
26 6.4.7 Average Power Meter..................................................................................6-18
27 6.4.8 Phase Transient Measuring Equipment ......................................................6-18
28 6.5 Functional System Set-ups..............................................................................6-19
29 6.5.1 Functional Block Diagrams........................................................................6-19
30 6.5.2 General Comments ....................................................................................6-21
31 6.6 Confidence Limits ...........................................................................................6-26
32 6.6.1 Confidence Level of Error Rate ...................................................................6-26
CONTENTS
xiii
1 6.6.2 Confidence on Power Measurement During Fading..................................... 6-30
2 6.6.3 Confidence Level of Detection Time............................................................ 6-31
3 ANNEX A: SELECTED PERFORMANCE REQUIREMENTS TABLES.............................. A-1
4 A.1 Forward Common Channel Performance Tables................................................. A-1
5 A.1.1 Non-Slotted Mode Paging Channel Performance Requirements ..................... A-1
6 A.1.1.1 Method of Measurement Test Parameters ............................................ A-1
7 A.1.1.2 Minimum Standards Requirements ..................................................... A-1
8 A.1.2 Slotted Mode Paging Channel Performance Requirements............................. A-2
9 A.1.2.1 Method of Measurement Test Parameters ............................................ A-2
10 A.1.2.2 Minimum Standards Requirements ..................................................... A-5
11 A.1.3 Forward Broadcast Control Channel Performance Requirements in AWGN
12 Channel...................................................................................................... A-6
13 A.1.3.1 Method of Measurement Test Parameters ............................................ A-7
14 A.1.3.2 Minimum Standards Requirements ..................................................... A-9
15 A.1.4 Forward Broadcast Control Channel Performance Requirements in
16 Multipath Fading Channel......................................................................... A-11
17 A.1.4.1 Method of Measurement Test Parameters .......................................... A-12
18 A.1.4.2 Minimum Standards Requirements ................................................... A-18
19 A.1.5 Forward Common Control Channel Performance Requirements.................. A-23
20 A.1.5.1 Method of Measurement Test Parameters .......................................... A-24
21 A.1.5.2 Minimum Standards Requirements ................................................... A-26
22 A.1.6 Common Assignment Channel and Common Power Control Channel
23 Performance Requirements........................................................................ A-29
24 A.1.6.1 Method of Measurement Test Parameters .......................................... A-30
25 A.1.6.2 Minimum Standards Requirements ................................................... A-31
26 A.2 Forward Traffic Channel Demodulation Performance Tables............................. A-33
27 A.2.1 Forward Traffic Channel Performance Requirements in AWGN ................... A-33
28 A.2.1.1 Method of Measurement Test Parameters .......................................... A-33
29 A.2.1.2 Minimum Standards Requirements ................................................... A-51
30 A.2.2 Forward Traffic Channel Performance Requirements in Multipath Fading
31 Channel.................................................................................................... A-73
32 A.2.2.1 Method of Measurement Test Parameters .......................................... A-74
CONTENTS
xiv
1 A.2.2.2 Minimum Standards Requirements....................................................A-83
2 A.2.3 Forward Traffic Channel Performance Requirements During Soft Handoff ...A-88
3 A.2.3.1 Method of Measurement Test Parameters...........................................A-89
4 A.2.3.2 Minimum Standards Requirements....................................................A-89
5 A.2.4 Power Control Bit Performance Requirements for Channels Belonging to
6 Different Power Control Sets During Soft Handoff.......................................A-89
7 A.2.4.1 Method of Measurement Test Parameters...........................................A-90
8 A.2.4.2 Minimum Standards Requirements....................................................A-90
9 A.2.5 Power Control Bit Performance Requirements for Channels Belonging to
10 the Same Power Control Set.......................................................................A-90
11 A.2.5.1 Method of Measurement Test Parameters...........................................A-91
12 A.2.5.2 Minimum Standards Requirements....................................................A-91
13 A.2.6 Power Control Subchannel Performance Requirements During Soft
14 Handoff .....................................................................................................A-91
15 A.2.6.1 Method of Measurement Test Parameters...........................................A-92
16 A.2.6.2 Minimum Standards Requirements....................................................A-92
17 A.2.7 Forward Traffic Channel Performance Requirements in Multipath Fading
18 Channel with Closed Loop Power Control (FPC_MODE = ë000í) ....................A-92
19 A.2.7.1 Method of Measurement Test Parameters...........................................A-92
20 A.2.7.2 Minimum Standards Requirements....................................................A-99
21 A.2.8 Forward Traffic Channel Performance Requirements in Multipath Fading
22 Channel with Closed Loop Power Control (FPC_MODE = ë010í) .................. A-104
23 A.2.8.1 Method of Measurement Test Parameters.........................................A-104
24 A.2.8.2 Minimum Standards Requirements..................................................A-112
25 A.2.9 Forward Traffic Channel Performance Requirements in Multipath Fading
26 Channel with Outer Loop Power Control and Closed Loop Power Control
27 (FPC_MODE = ë000í, ë001í and ë010í)......................................................... A-119
28 A.2.9.1 Method of Measurement Test Parameters.........................................A-120
29 A.2.9.2 Minimum Standards Requirements..................................................A-123
30 A.2.10 Forward Traffic Channel Performance Requirements in Multipath Fading
31 with Closed Loop Power Control (FPC_MODE = ë000í) and Transmit
32 Diversity (OTD or STS)............................................................................. A-124
33 A.2.10.1 Method of Measurement Test Parameters.........................................A-125
34 A.2.10.2 Minimum Standards Requirements..................................................A-129
CONTENTS
xv
1 A.2.11 Forward Traffic Channel Performance Requirements in Multipath Fading
2 with Closed Loop Power Control (FPC_MODE = ë010í) and Transmit
3 Diversity (OTD or STS) .............................................................................A-134
4 A.2.11.1 Method of Measurement Test Parameters ........................................ A-134
5 A.2.11.2 Minimum Standards Requirements ................................................. A-137
6 A.2.12 Power Control Subchannel Performance Requirements During Reverse
7 Pilot Channel Gating ................................................................................A-139
8 A.2.12.1 Method of Measurement Test Parameters ........................................ A-139
9 A.2.12.2 Minimum Standards Requirements ................................................. A-139
10 A.2.13 Power Control Subchannel Performance Requirements During Reverse
11 Fundamental Channel Gating...................................................................A-140
12 A.2.13.1 Method of Measurement Test Parameters ........................................ A-140
13 A.2.13.2 Minimum Standards Requirements ................................................. A-140
14
发表于 2017-12-21 13:52:08 | 显示全部楼层
多谢分享
GMT+8, 2025-9-19 07:21 , Processed in 0.019915 second(s), 6 queries , Gzip On, Redis On.
