查看: 2640|回复: 1
[招聘] Nvidia后端部门内推
发表于 2013-8-5 17:54:36 | 显示全部楼层 |阅读模式
nvidia(上海)后端部门招聘timing相关engineer,以下是职位要求。有意者可发简历到hbaifenbai@126.com
Department: GPU
Job Description/Qualifications:
As a senior member of our ASIC-PD team, you'll be working on streamlining the chip infrastructure process across product designs, focusing on full chip layout planning (partitioning, planning clock distribution and other structure, methodology), partition/full chip timing closure (primetime scripts, other tools, etc) and gate-level design of high-speed logic
  • Chip integration and netlist generation
  • Synthesis, Formal verification, netlist quality check
  • Work in conjunction with Place and Route Engineers to achieve timing closure for both partition level and full chip level
  • Develop and enhance entire timing flow from frontend (pre-layout) to backend (post-layout) at both chip and block level.
  • Develop custom timing scripts using tcl/primetime for clock skew analysis, special circuits such as clock dividers, core logic <-> IO macros interfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
  • Develop flow to physically partition and floorplan the entire chip.
  • Develop scripts for performing ECO's.
Minimum Requirement:
  • BS or MS in Electrical Engineering or Computer Science
  • Above 3 years of relevant ASIC experience ideally with a focus in the chip integration /synthesis/formal and timing closure
  • Excellent scripts skills
  • Excellent written and verbal communication skills in English
  • Ability to multiplex many issues, set priorities, and work in a team environment
  • Keep up to date with leading edge technologies
发表于 2013-8-6 13:32:15 | 显示全部楼层
b帮我内推下吧,简历已发送。。。。。
GMT+8, 2025-12-13 22:40 , Processed in 0.018056 second(s), 7 queries , Gzip On, Redis On.
