查看: 3616|回复: 5
IDT/ICS/ACTEL datasheet
发表于 2007-1-26 11:16:27 | 显示全部楼层 |阅读模式
1.大量IDT/ICS/ACTEL datasheet
2.可以直接联系我
MSN:zhang_hui_vip@hotmail.com
Mail:flex_zhang@maxtek.icrep.com.tw
Tel:021-54262185 Ext:205
3.如不清楚具体料号,可以备注IC function
 楼主| 发表于 2007-1-26 11:39:52 | 显示全部楼层
LOW ON-RESISTANCE WIDEBAND/VIDEO QUAD 2-CHANNEL MUX/DEMUX
IDTVS330: LOW ON-RESISTANCE WIDEBAND/VIDEO QUAD 2-CHANNEL MUX/DEMUX
FEATURES:
• High-performance solution to switch between video sources
• Wide bandwidth: 600MHz
• Low On-Resistance: 5Ω typical
• Low crosstalk at 10MHz: –80dB
• Ultra-low quiescent power (0.1μA typical)
• Fast switching: 10ns
• 8KV on connector side
• Available in SOIC and QSOP packages
DESCRIPTION:
The IDTVS330 is a true bidirectional Quad 2-channel multiplexer/
demultiplexer recommended for both RGB and composite video switching
applications. The video switch can be driven from a current output RAMDAC
or voltage output composite video source.
Low On-Resistance and wide bandwidth make it ideal for video and other
applications. Also this device has exceptionally high current capability which is
far greater than most analog switches offered today. A single 5V supply is all
that is required for operation.
The IDTVS330 offers a high-performance, low-cost solution to switch
between video sources. The application section describes the IDTVS330
replacing the HC4053 multiplier and buffer/ amplifier.
VS330.pdf
102.03 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Analog mux/demux
 楼主| 发表于 2007-1-26 12:52:23 | 显示全部楼层
可帮助申请样片哦
1.附件里产品线,均可提供相关样片和资料,供参考!
2.可以MSN直接联系我.
lacewood_introduce(上海圣晖电子IC介绍).pdf
442.05 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
lacewood_introduce
发表于 2007-1-31 20:02:01 | 显示全部楼层
支持以下啊!!!!!!!
发表于 2007-1-31 21:05:34 | 显示全部楼层
发表于 2014-4-27 02:25:58 | 显示全部楼层
great post
GMT+8, 2025-11-14 00:54 , Processed in 0.021944 second(s), 6 queries , Gzip On, Redis On.
