查看: 20660|回复: 78
HFSS 15.0.3 path for win64
发表于 2013-6-27 21:27:53 | 显示全部楼层 |阅读模式
HFSS 15.0.3 path. Old crack for 15.0.2 still works according to tests on my computer. Hope it helps!
HFSS 15.0.3 补丁。自己电脑上的测试表明以前15.0.2的crack继续有效(自己装上后把以前15.0.2的crack程序又运行了一遍,使用无问题)。
HFSS 15.0.3 Service Pack Updates
Enhancement: HFSS 15.0.3 introduces a new 3D electrical layout interface. To utilize it, download and install ANSYS Designer 8.0.3.  Then, launch ANSYS Designer, and insert an EM design type into the Designer desktop (Project > Insert EM Design...)
DE54625: HFSS will now reanalyze the last pass using the copied mesh for geometrically-equivalent design variations when the user selects the "Copy geometrically equivalent meshes" Optimetrics' option.
DE56281: Radiated field computation will no longer be affected by enabling/disabling differential pairs.
DE53254: The calculation of near fields in the post processor are now accurate for designs with metallic IE regions.
DE57316: The HPC for multiprocessing option will no longer adversely affect matrix assembly performance during a simulation relative to standard MP.
DE51696: An appropriate warning message now appears if a project is opened that contains designs for which licenses are not available.  Closing the project without saving now does not cause any loss of data.
DE57722: Optimizations that utilize the MATLAB optimizer now gracefully abort when a variation fails to solve.
DE51920: The curved object visualization setting works correctly for all models irrespective of the "face by face" faceting option (see Tools/Options/Modeler Options/Display).
US66895: Licensing changes
            - HFSS will now check out the hfss_gui license when users insert an HFSS-IE design or open an existing HFSS-IE design.
            - HFSS will now attempt to check out the "designer_desktop" license if the "hfss_desktop" license is unavailable.
            - Designer will now attempt to check out the "hfss_desktop" license if the "designer_desktop" license is unavailable.
HFSS1503Win64Patch.part1.rar (14.31 MB , 下载次数: 1158 )
HFSS1503Win64Patch.part2.rar (14.31 MB , 下载次数: 561 )
HFSS1503Win64Patch.part3.rar (14.31 MB , 下载次数: 548 )
HFSS1503Win64Patch.part4.rar (14.31 MB , 下载次数: 737 )
HFSS1503Win64Patch.part5.rar (4.8 MB , 下载次数: 330 )
发表于 2013-6-27 22:02:23 | 显示全部楼层
谢谢,跟一个
发表于 2013-7-3 21:33:09 | 显示全部楼层
谢谢楼主了,没想到最近更新挺快的。
发表于 2013-7-4 23:26:52 | 显示全部楼层
谢谢楼主分享
发表于 2013-7-5 11:07:12 | 显示全部楼层
又有新的更新了,0.2的都没钱下呢,也只能顶顶了
发表于 2013-7-11 17:06:27 | 显示全部楼层
确实挺快的
发表于 2013-8-9 23:22:21 | 显示全部楼层
回复 1# ywxwszc
   信元消耗太快了!
发表于 2013-8-9 23:43:33 | 显示全部楼层
为什么我用maxthon下载,每次扣5分啊?提示是扣1分啊
发表于 2013-8-10 12:33:23 | 显示全部楼层
good job!!!
发表于 2013-8-14 14:05:44 | 显示全部楼层
有32位的updates不?从哪里下载
GMT+8, 2025-12-17 00:35 , Processed in 0.027662 second(s), 7 queries , Gzip On, Redis On.
