查看: 5168|回复: 0
寻求GPS 蓝牙功能的声音记录仪研发
发表于 2013-6-20 14:15:50 | 显示全部楼层 |阅读模式
我这里急需研发一种新产品,设计要求如下,哪位懂设计的工程师能做兼职设计这款产品,请和我联系:15888861058 Q:151694193
Voice recorder with GPS and Bluetooth
List of components:
1)
CPU
2)
DIP switches (bitrate selection: 32/64/128kbps; sampling rate selection: 22kHz/44kHz)
3)
FLASH memory (microSD card slot)
4)
GPS module
5)
Bluetooth module (Supports Classic and Low Energy profiles)
6)
Microphone
7)
Vibro (Loss of communication, Low power indication, Power up/down indication)
8)
Beeper (Loss of communication, Low power indication, Control Button press confirmation)
9)
LED indicator (Recording mode indication)
10) Control button (Short press – Start/Stop recording, Long press – power up/power down device)
11) Battery
Functional description:
When Control button pressed, then start recording voice, pressed second time – stop recording, then add GPS-coordinates and time/date stamp to MP3 file (this information could be added to MP3 ID3 tags fields); save recording to FLASH memory. Device needs to support Bluetooth OBEX File Transfer Protocol.
Additional features:
1)
Small clip-on rugged water splash protected design
(example - http://www.kickstarter.com/proje ... -lifelogging-camera)
2)
Ability to send battery level and other technical information to smartphone
3)
Long battery life (…….1 week?)
General notes:
1)
If GPS module makes device expensive or power inefficient, this GPS could be excluded
2)
Future extensions will include:
a.
Non-contact induction charging (similar to Nokia Lumia)
b.
Front surface, made of Solar Battery
c.
Adding CPU with Bluetooth-DUN networking capability to transfer stored files to the external Internet server
Options 2.a and 2.b could be possibly integrated inside silicon protection case for the device.
GMT+8, 2025-12-25 21:32 , Processed in 0.027688 second(s), 8 queries , Gzip On, Redis On.
