查看: 5635|回复: 4
[讨论] ansoft designer and virtuoso
发表于 2013-4-30 13:49:19 | 显示全部楼层 |阅读模式
can anyone upload material for export layout from virtuoso to ansoft designer ?
i connect ansoft designer to cadence but i can't define ansoft port  for simulate with hfss!!!
发表于 2013-6-13 00:43:31 | 显示全部楼层
回复 1# mabas.masood loser
Ansys Designer & Nexxim v8.0.2 + license & crack
http://bbs.eetop.cn/thread-391576-1-1.html
 楼主| 发表于 2013-6-13 01:30:49 | 显示全部楼层
virtuoso and ansoft
 楼主| 发表于 2013-6-13 02:27:24 | 显示全部楼层
回复 2# hi_china59
virtuoso is run in linux but this soft that you upload windows version of designer
i can crack software and upload
发表于 2013-6-13 06:32:27 | 显示全部楼层
回复 4# mabas.masood
   I guess you could only convert the passive component from virtuoso to hfss or siwave to do em simulation(using ecad or ansoftlink?), the active components maybe can be exported as spice netlist? but I have never tried this flow.
GMT+8, 2025-9-19 05:27 , Processed in 0.017829 second(s), 5 queries , Gzip On, Redis On.
