查看: 1609|回复: 1
[招聘] Cadence SH 招聘 Lead Product Validation Engineer
发表于 2013-2-27 18:12:20 | 显示全部楼层 |阅读模式
If you have interest,PLS send your CV to zhangyl@cadence.com
欢迎应届博士或者有工作经验者投递
Job Title:
Lead PV Engineer
Position Description:
This job is an important addition to our R&D team to develop Cadence Encounter Digital Implementation System (EDI)
Responsible for developing, applying, and improving quality standard for Cadence EDI products
Required to acquire expertise and ownership over existing product components as well as develop brand new product features.
Help identifying new technology challenges in advanced process nodes and proactively provide the product improvement suggestion to R&D
Build up EDI expertise and deliver support to field team and customers whenever needed
Position Requirements:
CS/EE BS degree with 5+ years or MS degree with 3+ years of EDA or IC design related experience.
Good experience with Place and Route design flow using EDA tools. Good knowledge of LEF/DEF.
Be familiar with IC back-end design flow, from netlist to gdsout.
Strong analysis/bedbug capability for technical issues, be detailed oriented with a focus on quality.
Good team player with strong written and verbal communication skills.
Be able to work under pressure, be able to work on multiple projects at the same time.
Good English read, write and communication Skill.
Job Title:
Lead PV Engineer-Software System
Cadence ICD Product Validation Regression system is the core system infrastructure of the whole Product Validation organization, which can greatly improve the whole organization's efficiency and boost the team productivity.
This position is responsible for the regression system and application development and maintanance.
The candidate need use all kinds of knowledge and skills to design and improve the system based on the business requirement for the organization operation and the existing system and related software/hardware environment.
Detailed Responsibility:
1. Analyze System and Business requirement, based on which design the system flow chart
2. Do the needful system/scripts maintenance/improvement
3. Communicate with related IT and PV team and drive to improve organization operation efficiency
4. Innovate on the next generation system to boost organization's efficiency
Bachelor with 4 years related experience or Master with 2 years related experience
1. Result driven and details focused working attitude
2. Excellent analytical skills and complex system problem solving skills
3. Strong technical experience in Unix/Linux usage
4. Strong Perl/Tcl/Cshell scripting
5. Good knowledge and experience in CGI programming
6. Good knowledge in SQL database
7. Knowledge in Web programing (javascript, php, Python, XML) is a strong plus
8. Knowledge in NFS/Distributed Processing/Server Farm/Network is a strong plus
9. Good written English and oral English is a strong plus
Job Title:
Lead PV Design Engineer
1.Work through synthesis flow and APR flow by solving different kind of issues and bottleneck, througn many designs.
2.Identify any timing/power/area issues within SYN/APR flow, and among flow interfaces.
Develop system for automation.
1.MS with 3 years work experience in design house or EDA company.
2.Good at STA, good at APR flow, including place, route, cts, optimization, and SI analysis
Know about RTL synthesis.
3.Good at unix scripts, cshell. Perl is a plus.
4.Strong ability in analysis and solving issues,
strong ability in facing difficulty and challenges.
Proactive in work.
5.Good English skill, communication skill and good team work.
发表于 2013-2-28 09:49:38 | 显示全部楼层
支持一下,简历已发
GMT+8, 2025-12-23 01:17 , Processed in 0.035257 second(s), 8 queries , Gzip On, Redis On.
