楼主: ald_syn_cad
Agilent ADS 2012.08 Patch
发表于 2013-2-4 15:45:33 | 显示全部楼层
回复 42# wz19840313
    8-在控制面板修改电脑设置,更改日期、日期或数字格式为"英语(美国)";注意格式为"中文(简体、中国)"会导致无法破解,或破解后无法使用。,加上这一步你就破解了,这是秘密,不要告诉别人,哈哈.
发表于 2013-2-4 15:50:24 | 显示全部楼层
您的帖子长度不符合要求。 当前长度: 0 字节 系统限制: 5 到 200000 字节
发表于 2013-2-4 16:31:52 | 显示全部楼层
谢谢分享!
发表于 2013-2-4 19:25:00 | 显示全部楼层
thank you very much!!
发表于 2013-2-4 22:48:20 | 显示全部楼层
看来还得请楼主再努力一把搞定这些问题,谢谢!
 楼主| 发表于 2013-2-5 00:50:49 | 显示全部楼层
发表于 2013-2-5 02:23:14 | 显示全部楼层
It's work perfect!
发表于 2013-2-5 02:41:02 | 显示全部楼层
ald_syn_cad
Thanks, but there is a lincense file in then SV1206 patch file, and request to set Environment variable, so what to do?
 楼主| 发表于 2013-2-5 03:46:11 | 显示全部楼层
ald_syn_cad
Thanks, but there is a lincense file in then SV1206 patch file, and request to set En ...
bean1234 发表于 2013-2-5 02:41
    There are 2 choices:
1- You want to run only SystemVue without installing ADS.
       In this case you need to define SYSTEMVUE_LICENSE_FILE variable. Both the licenses are working in this case.
2- You want to use both ADS and SyetemVue.
       In this case you should not use SystemVue's License file and you must use only ADS license. SYSTEMVUE_LICENSE_FILE variable is not needed but if you don not want to delete SYSTEMVUE_LICENSE_FILE variable, ok no problem, in the path just point to the ADS license.
Finally, ADS license works for both tools.
发表于 2013-2-5 10:43:15 | 显示全部楼层
回复 53# ald_syn_cad
   能不能解决设置时区的问题?谢谢!
GMT+8, 2025-11-22 19:05 , Processed in 0.022908 second(s), 3 queries , Gzip On, Redis On.
