查看: 5802|回复: 5
Cadence Allegro SPB 16.6 Hotfix S002
发表于 2013-1-28 10:22:44 | 显示全部楼层 |阅读模式
Cadence SPB16.6已经推出,需要的朋友可以点击下面的链接下载:
http://dl.vmall.com/c0bg09o5dr
Cadence SPB16.6 SuperHotfix002发布,具体修复问题如下:
DATE: 12-21-2012   HOTFIX VERSION: 002
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
491042  CONCEPT_HDL    SECTION          Prevent PackagerXL from changing visibility on SEC attribute
863928  ALLEGRO_EDITOR INTERACTIV       Segment over void higlights false "nets with arc"
1067272 PCB_LIBRARIAN  CORE             Unable to retain the symbol outline changes
1074820 ALLEGRO_EDITOR GRAPHICS         losing infinite cursor tracking after selecting the add text command with opengl enable
1075622 CONCEPT_HDL    CORE             PDV Edit Symbol in DE-HDL all editing functions disabled since Hotfix 33
1076986 APD            WIREBOND         Wirebond Adjust Min DRC does not maintain the finger position in the same sequence
1078031 SIG_INTEGRITY  REPORTS          Requesting improvement to progress indicator for report generator
1080213 SIP_LAYOUT     WIREBOND         Wrong behavior of Redistribute Fingers Command
1080667 ALLEGRO_EDITOR GRAPHICS         Allegro lines with fonts not displayed correctly in 16.6
1080982 CONCEPT_HDL    CORE             Crash of Allegro Design Entry during a copy of a note.
1081200 CONSTRAINT_MGR OTHER            In the DIFF_PAIR worksheets various Analysis seem to take a long time to complete.
1081553 CONCEPT_HDL    OTHER            Model Assignment can not translate M (Milli-ohm) property value of DE HDL.
1081696 ALLEGRO_EDITOR INTERACTIV       Compose shape not working when radius is set to 1.0
1082595 ALLEGRO_EDITOR COLOR            Infinite cursor remains white even we change background to white
1082704 ALLEGRO_EDITOR GRAPHICS         infinite cursor disappears when using Display>Measure
1082715 SIG_EXPLORER   INTERACTIV       Single line impedance for BOTTOM Layer is not calculated in cross section upon changing the thickness of dielectic layer
1082774 ALLEGRO_EDITOR TECHFILE         Import techfile command terminates abnormally when importing a generic techfile.
1082820 CONSTRAINT_MGR UI_FORMS         The configure generic cross-section pull downs do not work.
1083133 SIP_LAYOUT     INTERACTIVE      SiP will crash when using the beta Pad Rename command to change a BGA pads name.
1083158 ALLEGRO_EDITOR GRAPHICS         The cursor chage to Arrow head for Shape Select is more sensitive to location in SPB 16.6
1083533 CONCEPT_HDL    CONSTRAINT_MGR   Bug -Net-count under few of the netclasses are not in sync between Schematics & Layout
1083637 PCB_LIBRARIAN  CORE             Save As is not renaming the NAME in the symbol.css file
1083934 ALLEGRO_EDITOR PAD_EDITOR       Error(SPMHUT-41): File selected is not of type Drawing.
1084148 CONCEPT_HDL    CHECKPLUS        The CheckPlus hasProperty predicate fails in the Physical environment.
1084166 SIP_LAYOUT     DIE_ABSTRACT_IF  Updating sip layout with new die abstract doesn't properly update IC_DESIGN_CELL* properties
1084285 CONCEPT_HDL    INFRA            Corrupted dcf was never fixed and caused PXL error
1084441 CONCEPT_HDL    CORE             Assigned net property value changes to numeric
1084542 ALLEGRO_EDITOR DRAFTING         Dimensions associated with frect doesn't rotate with the symbol.
1084736 APD            IMPORT_DATA      Import SPD2 file from UPD-L shape Pad and text issue
1085008 ALLEGRO_EDITOR INTERACTIV       Relative (from last pick) option in the Pick dialog not working for pick command
1085139 ALLEGRO_EDITOR GRAPHICS         Infinite Cursor disappear during Add Connect if Infinite_cursor_bug_nt is enabled
1085187 SIP_LAYOUT     INTERFACE_PLANNE netrev with overwrite constraints fatal error
1086402 ALLEGRO_EDITOR GRAPHICS         Infinite cursor dissapear when using command like add connect or Place manually with opengl enabled.
1086905 PSPICE         SIMULATOR        PSpice crash while simulating circuit file with BREAK function
1087770 ALLEGRO_EDITOR EDIT_ETCH        Allegro crashes on a pick with the slide command.
1088412 SCM            CONCEPT_IMPORT   why reimport block adds _1 to the netnames?
1088958 CONSTRAINT_MGR INTERACTIV       annot create Differential Pairs out of nets that belongs to a Net Group
1089336 ALLEGRO_EDITOR GRAPHICS         infinite cursor and pcb_cursor_angle
1090689 ADW            LRM              LRM: Unable to select any Row regardless of Status
1090955 ALLEGRO_EDITOR OTHER            Cancel command crashes PCB Editor when add rectangle
1091047 ALLEGRO_EDITOR REPORTS          The "Dangling Lines Via and Antenna� report seems to be missing vias that are antennas.
1091218 ADW            LRM              LRM is not worked for the block design of included project
1091443 ALLEGRO_EDITOR OTHER            Crash when toggling suppress pads
1091706 ALLEGRO_EDITOR EDIT_ETCH        Allegro crash while routing after setting variable acon_no_impedance_width
1092916 CAPTURE        OTHER            Capture crash
1093573 ALLEGRO_EDITOR DATABASE         team design opening workflow manager crashes allegro.  possibly corrupt database
发表于 2013-2-10 22:26:00 | 显示全部楼层
不错,非常感谢分享
发表于 2013-2-13 13:18:24 | 显示全部楼层
thank you man..
发表于 2013-5-4 09:54:22 | 显示全部楼层
哪里下载hotfix?
发表于 2013-8-18 22:53:33 | 显示全部楼层
12345,我等你等得好辛苦!!
发表于 2014-7-24 15:06:37 | 显示全部楼层
多谢楼主分享
GMT+8, 2025-12-19 14:03 , Processed in 0.018448 second(s), 4 queries , Gzip On, Redis On.
