楼主: real
Huijsing - Operational Amplifiers Theory and Design, Kluwer
发表于 2009-6-22 18:13:55 | 显示全部楼层
xiexie `````````
发表于 2009-9-8 09:46:59 | 显示全部楼层
This book can be an excellent resource for any Analog IntegratedCircuit Design Electrical Engineering student or practicing engineer.The book can assist in the modeling of IC devices such as transistors,resistors, and capacitors. It also sensibly covers the building blocksof analog integrated circuits: gain stages, output stages, levelshifters, current sources and mirrors.
发表于 2009-9-8 09:48:20 | 显示全部楼层
The reader is expected to have a general understanding of electronics,frequency-domain analysis procedures, and understand basic Pspiceoperations. The book generally covers enough material for a half-yearof courses at the upper-division/graduate level although the book couldcertainly be useful for a single class.
发表于 2009-9-8 09:50:26 | 显示全部楼层
he material generally starts out as basic and proceeds to a complexlevel. There are helpful figures and diagrams on nearly every page andthe organization is generally sensible and intuitive. There are manyworked examples and hundreds of end-of-chapter problems. The text issupported by a website that offers downloadable design projects,additional examples, and design software. Franco has done an admiraljob at presenti
发表于 2009-9-8 09:51:54 | 显示全部楼层
发表于 2009-9-8 09:54:55 | 显示全部楼层
发表于 2009-9-8 09:57:01 | 显示全部楼层
This is a very good intermediate text for op amp design. Someacquaitance with op amps will be needed before reading this bookbecause the learning curve is steep in the first chapter. However, theapproach is thorough and professionally presented. The book is morethan a cookbook. Furthermore, the book does not stop with the single opamp, but discusses the use of op amp(s) in circuits. The book isperfectly suited for prototyping the many circuits contained betweenits two covers. Since my interest was in instrumentation amplifiers, Idecided to reduce the circuits of chapter 2 to practice. It was a reallearning experience. I think chapter titles will further indicate thecomprehensive nature of the book: (1) OA Fundamentals, (2) Circuits w/Resistive Feedback, (3,4) Active Filter, (5) Static OA Limitations, (6)Dynamic OA Limitations, (7) Noise, (8) Stability, (9) NonlinearCircuits, (10) Signal Generators, (11) Voltage References andRegulators, (12) D-A & A-D Converters, (13) Nonlinear Amplifiers& Phase-Locked Loops.
发表于 2009-9-8 09:58:43 | 显示全部楼层
发表于 2009-9-8 10:00:42 | 显示全部楼层
Really a top notch book on op-amps and almost anything you'd ever dowith them. Has math where it's needed and rules of thumb where itisn't. Actually is just a great analog design book altogether. Reallythe definative text on the subject of designing with op-amps.
发表于 2009-9-8 10:01:57 | 显示全部楼层
GMT+8, 2025-11-5 03:56 , Processed in 0.020371 second(s), 3 queries , Gzip On, Redis On.
