查看: 36945|回复: 28
Cadence Allegro SPB 16.6 Hotfix S001
发表于 2012-12-20 15:01:58 | 显示全部楼层 |阅读模式
Cadence Allegro SPB 16.6 Hotfix S001现在已经提供下载了!Cadence Allegro SPB V16.60已经推出补丁文件了!
现在提供下载地址:http://www.orcad.nl/patches/Hotfix_SPB16.60.001_wint_1of1.exe
目前可以下载,并且成功安装了!
修订的内容很多:
DATE: 12-18-2012   HOTFIX VERSION: 001
===================================================================================================================================0 _9 ?  ~9 j0 r$ I! j1 v
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
===================================================================================================================================; E$ e. B) P: g8 v
501079  ALLEGRO_EDITOR MODULES          Enhancement for Module swap function similar to component swap
745682  CONCEPT_HDL    CORE             Attributes window requires resizing each time DEHDL is launched; o' a0 H; ^4 }: K" Q6 z- f
825846  CONCEPT_HDL    CORE             The module_order.dat file gets corrupted
871886  CONCEPT_HDL    CORE             Browse button in Signal Integrity window of DE-HDL option causes program crash
891439  ALLEGRO_EDITOR INTERACTIV       moving cline segments5 M2 L$ r6 k3 H9 B3 G' b7 G
898029  CAPTURE        PRINT/PLOT/OUTPU ENH: TCL:To show net alias clearly in print out if alias has underscore: u" p$ s5 c' {; Y7 R9 \* m
923210  CONCEPT_HDL    CORE             Search with multiple properties does not show all properties% q+ L( H' ]  b/ `3 o4 K
938977  CONCEPT_HDL    CORE             Properties attached to standard/DRAWING symbol does not propagate to parts placed in the schematic
947451  ALLEGRO_EDITOR INTERACTIV       Allow the tool to select multiple shapes when assigning a net to more than one shape.
968646  ALLEGRO_EDITOR EDIT_ETCH        The Cline to Pad spacing not followed for Multidrill pad it is more then minimum spacing
976723  ADW            MODEL_MANAGEMENT SI DML Model has to be provided the Auto Generate function for discrete components on DBeditor, A2 D; \7 [, x! S
981767  SCM            UI               Add series termination in ASA will crash if both output and input pins are selected.4 q7 O+ \& L2 Y1 T  ~, T( n+ l
982273  SCM            OTHER            Package radio button is grayed out
988438  CONCEPT_HDL    CORE             Visible constraint disrupts MOVE command5 q& I+ C" D) r& P& X
989471  ALLEGRO_EDITOR INTERACTIV       Functionality to zoom to the selected object in Pre Select Mode
993562  CONCEPT_HDL    INFRA            After upreving the design save hierarchy is leading to WARNING(SPCOCD-34).
996577  SPECCTRA       ROUTE            Specctra not routing NET_SHORT connections+ R6 \$ [* R& V' E5 z8 G- a7 c5 j: `
997992  CONCEPT_HDL    CORE             Why are Page Numbers not enumerated correctly when multiple TOC Symbols are used?/ t4 p! e( V0 E& @) x- u/ ?
1001300 PSPICE         MODELEDITOR      BUG: Simserver crash with encryptedm model% Y) A$ |- x  h* G3 c4 \8 g) D; u
1010124 PSPICE         SIMULATOR        Monte Carlo summary doesn't list all the runs in case of Convergence error in one of the runs
1013656 SCM            OTHER            create diff-pair should honour diff-pair setup or ask user for positive negative leg
1013721 ALLEGRO_EDITOR EDIT_ETCH        Routing near a 2x3 multi drill padstack does not maintain the spacing constraints.
1016859 SCM            REPORTS          dsreportgen exits with %errorlevel%0 ]5 {2 ]& U9 ~. m1 W9 B
1018506 ALLEGRO_EDITOR INTERACTIV       Edit copy with retain net of via will assign net to pin
1020746 CONCEPT_HDL    OTHER            PDF Publisher tool behavior inconsistent between OSs8 @$ B; G" e- D0 N* N, g$ G
1020798 SIP_LAYOUT     SHAPE            Shape not voiding on layer 2 causing shorts' E) l% x) E. q# q  I, A2 L9 R
1023051 SCM            UI               Wrong and incorrect message is generated while adding connectivity in SCM matrix view � DSTABLE-140  M3 y6 h* _, }9 O
1023774 APD            WIREBOND         After "xml wire profile data" is imported it isn't reflected to actual wire." }3 O- E' K9 B5 x- P  m+ k9 _0 `
1023807 SPECCTRA       GUI              Unable to close SPECCTRA using File > Quit or by clicking on standard window red close cross button  @3 v4 |  V4 K3 C8 k
1024239 ALLEGRO_EDITOR INTERFACES       DXF pin location is moved when I execute DXF out, c0 w" @2 ~9 E8 N8 W- S
1028237 CONCEPT_HDL    HDLDIRECT        Error binding design when generating simulation netlist: D9 V+ e: D& Z
1030591 CAPTURE        LIBRARY          Library Correction utiltiy locks the library and deosn't frees it even after being closed2 h, h. N# B4 e+ d5 V9 \4 b0 ?! w
1035624 CONCEPT_HDL    CORE             Options pre-selected when launching base product2 L, k* i4 ~5 Z/ R6 n8 O
1035896 SIP_LAYOUT     ASSY_RULE_CHECK  Rule Wire Length under Wire on line in Assembly Rule Checker doesn't work correctly3 v0 B! r* b! X- k1 t
1036580 ALLEGRO_EDITOR MODULES          Module created from completely routed board file has lot of missing connections in it.2 S5 A8 \. C( @# }2 a. E7 q9 {! n  H
1037345 ALLEGRO_EDITOR INTERACTIV       Enhance Allegro's Snap-To tools to select the origin of a sub-drawing(clip file)
1038180 ALLEGRO_EDITOR DRC_CONSTR       BGA escapes not being calculated in phase tol
1038285 SCM            UI               Restore the option to launch DE-HDL after schgen.' Z% n0 c2 S" M* m
1038371 ALLEGRO_EDITOR INTERFACES       Import > IDF fails with error "(SPMHDB-187): SHAPE boundary may not cross itself."5 a( d& o) i) ]" K
1038577 ALLEGRO_EDITOR DATABASE         Modifying Void crashes Allegro
1039112 ALLEGRO_EDITOR ARTWORK          Antietch and Boundary layers deleted when Match Display selected
1039147 ALLEGRO_EDITOR COLOR            Need an option to change color of Text marker and Text select in Display listing
1040653 ALLEGRO_EDITOR DATABASE         Cannot update netlist data,  ERROR(SPMHDB-121): Attribute definition not found.- f( F; G9 e3 }+ d' C
1041368 APD            DEGASSING        The Degas_No_Void properties assigned to Cline does not work.
1041864 ALLEGRO_EDITOR MANUFACT         Allegro crashes when opening the Backdrill setup menu
1042199 SIG_INTEGRITY  SIMULATION       Waveform list was not refreshed by switching tab.6 ]" `5 ?, b! D4 S5 n: ?% w
1042348 SIP_LAYOUT     STREAM_IF        GDSII export includes the full refernce path, breaks CATS flow
1043861 SIG_INTEGRITY  REPORTS          Derating values are NA in bus simulation report when derating table is not in working directory
1043903 GRE            GLOBAL           This design crashes during planning phases in GRE.- V$ \$ [; A- X9 ~8 x& B
1044029 PSPICE         ENCRYPTION       Encrypted lib not working for attached
1044222 ALLEGRO_EDITOR INTERACTIV       Capture Canvas Image changes working directory+ \. k1 ?( {) |5 U  r2 q
1044264 PSPICE         SIMULATOR        Why does the 'ORPSIM-15009:This device scales to 0.0 at this Temperature' Error occur.
1044577 GRE            CORE             Plan > Topological either crashes or hangs GRE* v! N( M6 M/ O4 z* x: B# D' D
1044687 TDA            CORE             tda does not get launched if java is not installed
1044754 SIG_INTEGRITY  SIMULATION       Incorrect waveforms when simulating with stacked die7 u: K. y5 }2 i- W1 ^0 x& U
1045607 ALLEGRO_EDITOR OTHER            Component get placed even after Cancel IDF in form.0 i2 i5 J, y7 Y7 d4 ^
1045694 CONCEPT_HDL    INFRA            Why to package the design twice to pass the net_short property to the board?9 z+ i, C5 l5 C. [
1045863 CONCEPT_HDL    INFRA            Customer had the crash several times when they run script with SPB16.51.
1046929 CONSTRAINT_MGR OTHER            Unable to create physical of spacing cset after rename the default cset in design entry.
1047590 ALLEGRO_EDITOR SCHEM_FTB        Buses created in Allegro-CM are deleted by netrev in traditional flow3 I+ j" a" K  I. S& o' n
1047823 CONSTRAINT_MGR OTHER            acPutValue predicate text not being displayed at bottom of Constraint Manager window.& M9 T% K0 e  @
1048403 ALLEGRO_EDITOR SKILL            Allegro crashes opening more than 16 files with skill+ F! R. c, O* q& b! d1 Q
1049262 ALLEGRO_EDITOR OTHER            APD and extracta crash owing to Wirebond., L0 K  V8 G4 b' Q" [' J
1049303 CONCEPT_HDL    CORE             Block rename deletes schematic data immediately in 16.5& ^3 y+ N# E. `6 @+ W0 W( ^  d
1049317 CONCEPT_HDL    OTHER            bomhdl with scm mode not working on RHEL in 16.5+ K+ b; F7 N+ A; ^
1049399 SIG_INTEGRITY  OTHER            Toggling z-axis delay in CM shows the same value7 X$ f2 V  H' g5 N2 c7 _
1049956 ALLEGRO_EDITOR DATABASE         BUG:dbdoctor deletes fillets as design is migrated from old version+ U8 D. B; E" k- r0 _
1050408 APD            DXF_IF           Symbol has 45 degrees rotation  in mcm but DXF doesn縯.$ i9 s/ _+ X1 n, {5 S, b7 e" [; g
1050483 ALLEGRO_EDITOR DRC_CONSTR       DRC has been waived but after updated DRC system generated a new DRC.
1050918 ALLEGRO_EDITOR MANUFACT         Testprep Automatic generate testpoints with wrong padstack Itype in SPB165S026.
1051588 ALLEGRO_EDITOR PAD_EDITOR       Pad_Designer library drill report omits some drill holes
1052005 SIG_INTEGRITY  OTHER            Huge difference in Z-Axis delay with the latest hotfix for 16.5 that did not exist in older ISR's of 16.5.! s4 s8 w" P+ Q  s/ n' L
1052045 ALLEGRO_EDITOR OTHER            Bug - Thermal relief connects not sustaining 15 degrees component spin in version 16.5 unlike v16.3
1052449 CONCEPT_HDL    COPY_PROJECT     Copy Project does not update all relative paths in the cpm file+ i& e2 \- C: v7 _0 A, C" X- `, O  C
1052600 ALLEGRO_EDITOR SHAPE            Adding a specific cline causing shape errors- P$ E7 ?5 A& r, [( m
1052753 ALLEGRO_EDITOR DRC_CONSTR       Allegro showing soldermask drc only when the symbol is rotated.0 |( A6 W4 n, Y" c6 Z2 i
1054235 ALLEGRO_EDITOR PLACEMENT        Cannot place alt_symbols for mechanical parts.! r( v' a, r+ {" a
1054269 ALLEGRO_EDITOR MANUFACT         Backdrill Setup and Analysis crashes on attached design
1054351 ALLEGRO_EDITOR SHAPE            Shape voiding fails for board having diffpairs with arcs- d& ^3 v' J- T1 c
1054456 ALLEGRO_EDITOR MENTOR           mbs2lib incorrectly translates refdes label
1055273 ALLEGRO_EDITOR INTERFACES       DXF exported from Allegro has an offset in pad location for Y- direction.
1055328 CONCEPT_HDL    COPY_PROJECT     Project Manager - Project Copy
1055481 APD            SHAPE            keepout does not clear shape unless it's picked up and dropped down/ z0 k9 e& C- u5 }2 E, Z
1055729 CIS            GEN_BOM          Standard CIS BOM per page is not working correctly with option  Process Selection4 z/ C6 ]& k7 @3 Q" k# x
1056418 ALLEGRO_EDITOR OTHER            PDF exports the blank text markers whether or not the markers are visible.9 s( }, ]3 ]' ?! p1 r* G. b
1056579 CAPTURE        OTHER            Ability to define custom variables for titleblocks that update for specific variant views
1057003 ALLEGRO_EDITOR SHAPE            Z-copy to create RKI does not follow board outline# f; O# h. H/ r
1057976 ALLEGRO_EDITOR DRC_CONSTR       No Same net Spacing DRC on attached design.
1058002 SIG_INTEGRITY  SIMULATION       Incorrect Xtalk sim netlist was created./ s8 U1 z) e8 |# z4 P# |1 E
1058364 ALLEGRO_EDITOR SKILL            axlTransformObject() is moving refdes text when only symbol pin is selected for move; `1 i" |/ b+ B) v  N) B
1058940 ALLEGRO_EDITOR INTERFACES       IDF(PTC) out command output wrong angle value! t* r" r/ V9 `1 z" A8 H2 Q
1059037 CIS            PLACE_DATABASE_P What enables the Refresh symbol libs option under hte update menu in CIS explorer
1059389 ALLEGRO_EDITOR MANUFACT         about back drill analisys report
1059901 CONCEPT_HDL    CORE             Global Property Change and <<OCC_DELETED>> property value.1 N3 G: g8 t: f4 U7 B5 V5 y* h: r% @
1060428 ADW            DESIGN_INIT      ADW Flow Manager Copy Project fails to complete
1060589 F2B            PACKAGERXL       Packager Fails with ERROR(SPCOPK-1053): Cannot find a ppt part that matches the instance properties.
1060977 F2B            DESIGNSYNC       back annotate in 16.5 does not bring in already placed nets as global nets
1061223 CONCEPT_HDL    CHECKPLUS        What determines a passthru pin?
1061424 CONCEPT_HDL    CORE             Customer creates <<OCC_DELETED>> property values.+ s8 e- B8 i& w: A
1061572 ALLEGRO_EDITOR INTERACTIV       Shortcut keys wont work after "Edit Text" command is finished.8 q8 p) M5 N! l
1061659 ALLEGRO_EDITOR DATABASE         Unable to return drawing origin to 00
1062558 APD            DXF_IF           If set both in X and Y offset DXF only get one and not get absolutely value in 45 degree rotation4 `. B' ~3 t7 W- \( E5 G" H
1062982 ALLEGRO_EDITOR MODULES          Module containg partitions has been imported to the main design and cant be refreshed.
1063284 PCB_LIBRARIAN  OTHER            PDV Save As is broken
1063658 ALLEGRO_EDITOR SCHEM_FTB        Allegro Import Logic does not remove library defined diffpairs8 G8 X3 i1 E$ {" s) X0 ^. \
1063778 CONCEPT_HDL    CHECKPLUS        The hasSynonyms CheckPlus predicate is not returning true for all global signals.
1063924 CONCEPT_HDL    CONSTRAINT_MGR   Highlight the net between DE-HDL 16.5 and Constraint Manager.! B% o8 U0 b2 M+ d7 ~7 J
1064707 CONCEPT_HDL    CHECKPLUS        Rules Checker core dumps on design  j; I, m; W9 U' P* L% K- h
1065124 PCB_LIBRARIAN  SETUP            PTF properties cannot be deleted from the setup in PDV
1065618 CONSTRAINT_MGR ANALYSIS         DRCs on board but Constraint Manager shows the columns as green.
1065641 PCB_LIBRARIAN  CORE             PDV symbol editor is crashing when deleting a group using delete or CTRL+X
1065745 SIP_LAYOUT     DATABASE         The logic assign net command crashes the application6 ]  ?: @0 C. t
1065860 ALLEGRO_EDITOR REPORTS          Design crashes when running a padstack usage report8 A& C* f- A, @/ [& {$ W$ J4 y
1066051 ALLEGRO_EDITOR TESTPREP         Auto Testprep generation creates TP with Testpoint to Component Locatin DRC
1066318 CONCEPT_HDL    CREFER           Issue with LOCATION visibility in flattened schematic/ S( [/ c8 X1 ^* G) k7 A
1067339 CONSTRAINT_MGR ANALYSIS         Relative Propagation Delay analysis in the Partition file seems very inconsitent.
1067984 SIP_LAYOUT     OTHER            layer compare batch fails with write protected file
1068425 F2B            DESIGNVARI       Out of memory message in Variant Editor while 縞hange properties&#65533; command( W4 o1 E) v  |  |' _
1068547 ALLEGRO_EDITOR EDIT_ETCH        Outward Fanout is not fanning out this 4 sided part as intended
1068966 SIP_LAYOUT     DRC_CONSTRAINTS  DRC update aborts on this design with  ERROR -3000067
1069215 CAPTURE        DATABASE         Capture Crash on usnig a TCL utltiy to correct design7 S5 p* H" ~- y, k* A# c" d
1069517 SIP_LAYOUT     DIE_EDITOR       change die abstract pins tab default action from delete to modify$ s; T2 d: o2 E! H  C9 U0 Z5 Q
1069915 ALLEGRO_EDITOR EDIT_ETCH        Allegro hangs with when doing spread between voids, o8 H  N. M# R$ N( W* |
1070007 ALLEGRO_EDITOR PLOTTING         Export IPF omits drill figure characters for backdrill holes+ S& u( o" A& a) @( `; D! W: Y, z! N
1071722 SIP_RF         DIEEXPORT        Virtuoso SiP Architect not writing out pins to the .dra needed for LVS flow
1072067 APD            EXTRACT          When expoting using Extracta oblong pads with anyangle are abnormal
1072791 ALLEGRO_EDITOR DATABASE         Database check cannot fix error and keep report the same issues cause artwork cannot export.7 W6 m' Y' A, d: B3 T2 _, i, k
1072806 CIS            EXPLORE_DATABASE Query tab in CIS explorer doesn't show searh fields in 16.6% H: F4 _  u' u: e, o
1072843 ALLEGRO_EDITOR PLACEMENT        The move command that was present in the right mouse pop up menu during manual placement is missing in 16.5
1072904 SIP_FLOW       SIP_LAYOUT       Probe pins not being mirrored in Die Editor correctly in Chip Down mode.
1073237 SIG_INTEGRITY  GEOMETRY_EXTRACT Some nets has no result at Bus Simulation and Comprehensive simulation.0 }% P2 R3 Q: n) M1 }2 t- v+ A9 B
1073445 ALLEGRO_EDITOR GRAPHICS         'infinite cursor graphics fail -ghost copies as you move cursor2 U# y7 j: u( \' g1 S) z
1073464 SCM            SCHGEN           Schgen never completes.1 t$ |6 @- a7 q" G2 G# s7 n/ G
1073587 SIP_LAYOUT     OTHER            axlSpreadsheetSetWorksheet command clears the cells in memory
1073745 CONCEPT_HDL    CORE             Import design fails* p& m# `* |' J0 e6 j/ R4 \/ U( f
1073852 ALLEGRO_EDITOR INTERACTIV       While doing a Copy Via use the last 'Copy Origin'
1074279 ADW            DSN_MIGRATION    Design Migration fails purge if there are cells with BODY_TYPE" r. J5 s  Z8 A7 M
1074791 CONCEPT_HDL    HDLDIRECT        User gets port exists in schematic but not on symbol message even though the port does not exist8 Y) S4 T; D" e" O' V! A
1075135 ALLEGRO_EDITOR DRAFTING         Ability to edit dimension text block in Instance Parameter
1075151 ALLEGRO_EDITOR SHAPE            Cannot change global shape parameter back to thermal width oversize after having used fixed thermal
1075256 ALLEGRO_EDITOR OTHER            Import > IPF in 16.5 is dropping data.8 P, a2 W  z+ {: G0 w! I
1075853 ALLEGRO_EDITOR REPORTS          please add "PART_NAME" at Extract UI8 V, ^! [2 T5 l% U6 Q9 o$ y' d
1075934 ALLEGRO_EDITOR DRAFTING         Able to Changing Dimension Text Block$ D( i$ k. q- \' h0 n, C7 e) D
1075955 CAPTURE        SCHEMATIC_EDITOR ZOOM in 16.6  using key "I" on keyboard in not centered on mouse pointer( A0 o% K" G* l: `$ w- R
1075964 ALLEGRO_EDITOR SHAPE            Shape voiding is not consistent in conjunction with odd angle and arc traces
1076086 SIP_LAYOUT     IMPORT_DATA      missing wirebond after import SPD2" _1 P. H) C( z  G& s3 ~
1076202 ALLEGRO_EDITOR EDIT_ETCH        Allegro add connect causing crash after Hotfix
1076205 CAPTURE        PRINT/PLOT/OUTPU : Printing of User Assigned RefDes
1076536 ALLEGRO_EDITOR DRC_CONSTR       Embedded component which protrude out toward Top do not create DRC with Place Keepout on Top9 [% p3 ^& L5 X
1076538 CONCEPT_HDL    CORE             Property visibility changes in attribute form not updated in schematic canvas.
1076655 APD            DXF_IF           Dxf does not get offset value if die symbol padstack has offset value5 H4 S9 |" I, L. R! L
1076846 ALLEGRO_EDITOR EDIT_ETCH        Grid snapping broken after slide in 16.6. |8 L4 v$ w4 q2 h! X6 s5 ?& S
1076891 ALLEGRO_EDITOR INTERACTIV       Symbol rotation not displayed correctly when defined as a funckey
1076909 ALLEGRO_EDITOR DRC_CONSTR       Allegro crashes while placing modules from database
1077084 CAPTURE        NETGROUPS        Crash on selecting bus when Enable Global ITC is unset
1077169 APD            SHAPE            Shape > Check is producing bogus results.3 y( D. `1 O3 x9 B4 _9 B7 t
1077572 ALLEGRO_EDITOR DATABASE         Mechanical symbol created with 16.6 cannot be placed on board.
1077879 ALLEGRO_EDITOR SKILL            Allegro Skill axlDBCreateFilmRec fails when 15th argument missing "draw hole only" for the first tim
1078380 SCM            OTHER            Custom template works in Windows but not Linux
1078497 ALLEGRO_EDITOR INTERFACES       Import DXF does not seem to work correctly.2 D+ O0 _$ _+ b* R' w& |& k
1078682 ALLEGRO_EDITOR DRC_CONSTR       Unaccetable slowness with Slide5 \, O- w* @/ j, b
1079082 ALLEGRO_EDITOR PLACEMENT        Swap components, gives error SPMHGE-616, when symbols instead of components are selected for swapping8 s+ F8 L4 d; ]  f9 T9 v& ]2 f8 p0 \
1079533 ALLEGRO_EDITOR PLACEMENT        Swapping components in 16.6 results in Error "E-(SPMHGE-616): Symbol and layer embedding requirements do not match"
1079937 CAPTURE        SCHEMATIC_EDITOR ZOOM in 16.6 is non uniform on text7 }; G& o7 B9 P' l" t9 I
1082582 ALLEGRO_EDITOR GRAPHICS         Allegro hangs on a given testcase using the MMB zoom control
1082981 ALLEGRO_EDITOR SKILL            Allegro crash while change the new symbol type as mechanical.) W" r: @. `' j  g
1083230 SIP_LAYOUT     SHAPE            Shape fill in 16.6 releaase not fillilng shapes as good as it did in the 16.5 release.
发表于 2012-12-20 17:38:44 | 显示全部楼层
支持一下共享精神!
发表于 2012-12-21 09:12:50 | 显示全部楼层
回复 1# micdot
    正在…………………………
发表于 2012-12-21 22:45:38 | 显示全部楼层
16.6终于有hotfix了。。不知道现在有没有人能完全破解这个版本了。
发表于 2012-12-23 13:20:56 | 显示全部楼层
没有 我用的是16.6的base版 不是很好 很大的改动
 楼主| 发表于 2013-1-2 12:10:22 | 显示全部楼层
回复 4# paulapequeno
    根据我现在的使用情况来看,32bit的系统使用16.5的破解程序即可。
 楼主| 发表于 2013-1-2 12:12:00 | 显示全部楼层
回复 5# shangyouqiang
    16.6的确改动了好多,但是我的感觉如果要想用16.6版本的话,就最好打上这个补丁——毕竟这个补丁就是针对16.6的base版本的一些bug而推出的。
发表于 2013-1-2 22:47:38 | 显示全部楼层
有linux版否?
发表于 2013-1-14 14:34:46 | 显示全部楼层
回复 8# micdot
请问打上补丁之后怎么破解啊?
 楼主| 发表于 2013-1-14 15:46:58 | 显示全部楼层
回复 10# yuzhoushenchu
   以16.6为例说明已经破解后安装HOTFIX的方法
不少人遇到破解之后安装HOTFIX不能使用、报错的问题,那是因为没有使用正确的安装方法。此方法只适合使用pubkey破解的16.3、16.5和16.6用户。
为何使用pubkey破解后的程序打上hotfix补丁再次破解会没法使用,原因不再详述。
基本思路:由于升级包是基于基础版(16.6)制作而成的,是历次升级补丁的合成体;升级包在安装的时候不进行原来数据的校验,只是一味地覆盖安装,所以可以使用替换法来完成以下步骤。
安装了cadence软件之后,已经破解好了的童鞋往下看:
1、首先把spb_16.6文件夹命名为spb_16.6old(反正和spb_16.6不一样就行了)。
2、在cadence目录里面建立一个新的空文件夹命名为spb_16.6,并把spb_16.6old的compnts.dat拷贝到空的spb_16.6中
3、安装HOTFIX补丁到空的spb_16.6中;
4、复制ToolsPubkey.bat pubkey1.30.exe pubkey 三个文件到spb_16.6\tools中并运行ToolsPubkey.bat
5、把spb_16.6里面的文件全部复制到spb_16.6old替换旧文件
6、删除spb_16.6文件夹并把spb_16.6old改回spb_16.6
你可以正常使用了!.
下次安装补丁只能往新版本装,比如装了hotfix28以后就只能装29而不能装27。新版本的HOTFIX会覆盖之前所有版本补丁所修改过的文件。
GMT+8, 2025-12-23 13:40 , Processed in 0.021034 second(s), 5 queries , Gzip On, Redis On.
