查看: 6034|回复: 10
求助ic615的不能启动
发表于 2012-10-30 20:53:43 | 显示全部楼层 |阅读模式
lmli出现以下The license server manager has found no vendor daemons to start
20:50:10 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
lmgrd exiting.
virtuoso&退出,出现以下
: Unable to get the Cadence(R) Design Framework II license feature of "111".
怎么破?是license的原因吗?
发表于 2012-10-31 11:34:57 | 显示全部楼层
回复 1# 284294022
    Which version you are using ? is it Base-ic615 or hotfix_ic615 ?
Also it seems you are using unofficial licence file, So you need to apply the patch.
发表于 2012-10-31 13:17:57 | 显示全部楼层
发表于 2012-10-31 15:14:08 | 显示全部楼层
有高手能提供一下IC61的license吗? 不胜感激呀
 楼主| 发表于 2012-10-31 19:24:48 | 显示全部楼层
回复 2# apsari950
应该是base版,64位的615好像没有合适的patch?
 楼主| 发表于 2012-10-31 19:31:40 | 显示全部楼层
回复 3# yulizi
   我试过,加不加demon那一行,运行都报111的错
发表于 2012-11-1 01:55:39 | 显示全部楼层
回复 5# 284294022
check the IC615 Patch and Licence file from the forum. Apply the Patch, and Setup the LM_LICENSE_FILE. start Virtuoso, it should work.
No need to run lmgrd. It is working for me.
发表于 2012-11-11 08:33:31 | 显示全部楼层
繼續加油!
发表于 2013-4-26 14:28:18 | 显示全部楼层
回复 6# 284294022
    good infom
发表于 2013-10-19 20:11:38 | 显示全部楼层
楼主这个问题解决了吗 ?我也遇到这个问题了 求救啊!!!
GMT+8, 2025-12-20 04:20 , Processed in 0.022322 second(s), 6 queries , Gzip On, Redis On.
