楼主: george3166
哪位可以分享Hspice 2012 License 文件?非常感谢!
发表于 2012-11-7 09:13:12 | 显示全部楼层
没软件,没lic
╮(╯_╰)╭
发表于 2012-11-7 12:31:55 | 显示全部楼层
I can do it.
发表于 2012-11-9 01:01:35 | 显示全部楼层
True,the Linux version has more features.
Tried blocking outgoing with firewall?
发表于 2012-11-9 06:48:45 | 显示全部楼层
回复 13# eric283
Thank you for your kind response. I do not know which URL's needed to be blocked and whether it is going to be successful. I am not as good to make a setup and verify that there would be no call before actually connecting to internet. Without that knowledge if I try for experimentation and it is able to call home once  that is all it takes If you know a solution in windows environment I would like to know also. If windows OK than at worst I could carry files using Flash driver from Linux and run at Windows.
发表于 2013-3-20 20:19:31 | 显示全部楼层
請問一下,HSPICE 2012有支援transient noise的功能嗎?spectre RF有PNOISE,好像沒有transient noise
发表于 2013-3-20 21:08:56 | 显示全部楼层
Thank you
发表于 2013-3-20 21:09:52 | 显示全部楼层
請問HSPICE 與Cadence的功能差在哪?
发表于 2013-4-10 01:40:04 | 显示全部楼层
does it work with old file
发表于 2013-8-11 00:06:35 | 显示全部楼层
楼主,可否上传下Hspice2012的安装文件?谢谢!
发表于 2013-8-28 21:30:31 | 显示全部楼层
hi every one i have downloaded hspice 2012 ... but i cant see anwaves and output.. it shows that i need flexlm license... i am new to this ... can any one help me out how to fix this problem please my email is laxmanaa.g@gmail.com
GMT+8, 2025-12-30 04:53 , Processed in 0.019582 second(s), 5 queries , Gzip On, Redis On.
