查看: 2561|回复: 2
[招聘] Analog IC Design Engineer for Computing Power Management (located in Shenzhen)
发表于 2012-10-16 15:40:21 | 显示全部楼层 |阅读模式
亲,合适的就投简历给我呗
AnalogIC Design Engineer for Computing Power Management (located in Shenzhen)
RoleSummary
Design themost advanced integrated analog and mixed signal power management IC forcomputing power management market.
PrimaryResponsibility
Development of state-of-art power managementutilizing leading edge BiCMOS/DMOS technologies.
Responsible for the entire productdevelopment process, being involved in product definition, circuit implementation,simulation, and debug, as well as playing an advisory role in IC layout andfloor plan, and test development, characterization and reliability.
Cost effective designs in a production environment completed in a timely manner is the ultimate goal on every project.
Products cover a wide range of circuit typesallowing a large breadth of technical knowledge to be gained.
Secondaryresponsibility
Work with systems and applications engineersto define cost effective, creative solutions that meet time to marketrequirements.
Design to IC specifications based on customerand market requirements.
Responsible for the design schedule, cost andperformance goals.
Support test engineering and productionrelease team for ramp to production.
Provide a robust, reliable, high performancedesign and layout that meets specified performance criteria within thespecified project schedule.
Interaction with Product, Systems,Application and Test engineering during the evaluation phase.
Requiredbasic Qualifications:
MSEE with analog-mixed signal IC design inBiCMOS process for a minimum 3 years experience.
High current and low current designs, opamps,gm/voltage amps, comparators, gate drivers, oscillators, high speed levelshifters, current limit, LDO, NVM, power LDMOS design, and basic digital logicdesign.
Understand the BICMOS process, devicephysics, and power electronics. Skilled with SPICE, Cadence AnalogArtist/Virtuoso/Silicon Ensemble design.
Teamand people skills:
The ideal candidate should be able to workeffectively in a team environment, leading the development team as needed toaccomplish the new product goals. Character and team building skills are essential to enabling on time delivery of IC’s.
Sharing information and mentoring otherdesigners less skilled or knowledgeable is a must.
 楼主| 发表于 2012-10-16 15:43:11 | 显示全部楼层
欢迎联络
LISYYE|ALLWAYS CONSULTING
Mail:lisy.ye@allways-consulting.com
QQ : 1720931809
All ways used,you win
 楼主| 发表于 2012-10-22 10:50:00 | 显示全部楼层
这个职位做好是做DCDC的人哦,如果是通讯类的产品那就更大发了。
走过路过不要错过啊
GMT+8, 2025-12-22 19:21 , Processed in 0.022020 second(s), 7 queries , Gzip On, Redis On.
