楼主: HeNavy
[原创] 利用cadence自身将cdb转换成oa格式的方法
发表于 2016-4-22 14:06:21 | 显示全部楼层
感谢分享!
发表于 2016-4-30 08:44:34 | 显示全部楼层
不错的资料哦
发表于 2016-5-8 13:20:31 | 显示全部楼层
楼主,我尝试着用这个方法来转换,但是提示缺少oa格式的TF文件如下:
ERROR   (CDBOA-500): Cannot translate CDB design library
                     "../designmodel_copy/bak" to OpenAccess because CDB
                     technology library "asmc035hv" referenced by the CDB design
                     library is not available in the OpenAccess format. Before
                     translating the CDB design library, ensure that all the
                     referenced CDB technology libraries are available in
                     OpenAccess and defined in 'cds.lib'.
Translation of library "bak" stopped.
Message Summary:
ERROR   (CDBOA-500): Cannot translate CDB design library <path>/<name> to
                     OpenAccess because CDB technology library <name> referenced
                     by the CDB design library is not available in the
                     OpenAccess format. Before translating the CDB design
                     library, ensure that all the referenced CDB technology
                     libraries are available in OpenAccess and defined in
                     'cds.lib'.
                      Generated once. The translator stopped because the CDBA
                     library references an attached technology library that does
                     not exist in OpenAccess.
                      Check the source library files and correct the library
                     attachments as required. Ensure that the cds.lib file is
                     present in the current directory and any technology library
                     that is referenced by the current library is defined in the
                     cds.lib file and is available in OpenAccess at the time it
                     is referenced. If the design library is referencing itself
                     as an attached technology library, ensure that there is an
                     appropriate tech.db technology file present in the
                     OpenAccess library directory.
请问该怎么解决?
发表于 2016-10-26 10:50:49 | 显示全部楼层
回复 1# HeNavy
   谢谢分享
发表于 2016-10-27 13:35:34 | 显示全部楼层
谢谢,
发表于 2016-12-1 20:45:35 | 显示全部楼层
总算解决了
发表于 2016-12-8 17:31:47 | 显示全部楼层
thanks for your sharing!
发表于 2017-2-24 15:24:23 | 显示全部楼层
转过就忘记了!多谢!
发表于 2017-3-12 15:40:11 | 显示全部楼层
多谢分享
发表于 2017-5-9 16:06:26 | 显示全部楼层
谢谢分享啊
GMT+8, 2025-10-13 08:30 , Processed in 0.704234 second(s), 3 queries , Gzip On, Redis On.
