查看: 3496|回复: 1
Mentor Nucleus ReadyStart
发表于 2012-8-11 01:58:18 | 显示全部楼层 |阅读模式
Free evaluation package is to explore the full functionality of the integrated development environment for the Nucleus RTOS and its extensive middleware portfolio.
Experiment with and run actual Nucleus code including graphical applications on the included QEMU based simulation environment. No hardware needed to run the pre-built demos, modify the provided examples or create your own Nucleus application.
What do you get?
  • EDGE Developer Suite with
    • Eclipse IDE
    • Compiler, Assembler, Linker, Debugger, Runtime Libraries
  • Binary Nucleus System Project
    • QEMU based Board Support Package (BSP)
  • Full ReadyStart Documentation
  • Demo and Example Applications
    • Kernel, File System and Networking source code examples
    • Binary Inflexion demo simulating an In Home Display
Download:
http://s3.mentor.com/readystart/qemu/setup.exe
Hompage:
http://www.mentor.com/embedded-software/downloads/
发表于 2013-9-15 12:42:44 | 显示全部楼层
如何破解
GMT+8, 2025-12-19 19:38 , Processed in 0.015518 second(s), 7 queries , Gzip On, Redis On.
