查看: 3537|回复: 1
centos6.3中安装ic6遇到问题
发表于 2012-8-7 08:37:29 | 显示全部楼层 |阅读模式
各位大侠,我在centos6.3中安装ic6遇到如下问题:
Exception in thread "main" java. lang.Unsatisfied Link Error: /home/eda/installscape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503)
        at java.lang.Runtime.loadLibrary0(Runtime.java:788)
        at java.lang.System.loadLibrary(System.java:834)
        at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Toolkit.java:1437)
        at java.awt.Toolkit.<clinit>(Toolkit.java:1458)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:70)
装不下去了,求助啊。。。。。。
发表于 2012-9-18 22:09:22 | 显示全部楼层
eda安装的图形界面都要用libXp.so.6,我装questasim的也是这样的,所以像ls说的,把libXp的库装上就好了
BTW,可以用RHEL4或者Centos4装,cadence推荐是使用这个系统
GMT+8, 2025-11-14 16:50 , Processed in 2.928732 second(s), 6 queries , Gzip On, Redis On.
