查看: 2940|回复: 3
深入理解Verilog中各种延迟:Interconnect and Module Path Delays
发表于 2012-7-10 16:22:56 | 显示全部楼层 |阅读模式
    Interconnect Delays
❑ Default Interconnect Delays
❑ Interconnect Delays and -intermod_path
❑ Pulse Handling
❑ SDF Annotation of Interconnect Delays
❑ PLI Annotation of Interconnect Delays
    Module Path Delays
❑ Specify Blocks
❑ Describing Module Paths
❑ Establishing Full or Parallel Connection Paths
❑ Assigning Delays to Module Paths
❑ Selecting a Delay When Multiple Delays Are Specified for a Path
❑ Specify Properties for Module Path Delays
❑ Mixing Module Path Delays and Distributed Delays
❑ Strength Changes on Path Inputs
❑ Driving Wired Logic Outputs
❑ Simulating Path Outputs That Drive Other Path Outputs
❑ Enhancing Path Delay Accuracy
❑ SDF Annotation of Module Path Delays
VlogDelays.pdf (308 KB , 下载次数: 72 )
发表于 2012-7-11 02:04:39 | 显示全部楼层
What is this ?
发表于 2017-8-17 22:57:29 | 显示全部楼层
参考阅读一下
发表于 2017-8-18 10:45:31 | 显示全部楼层
看一下 再说 !
GMT+8, 2025-12-14 01:38 , Processed in 0.021510 second(s), 4 queries , Gzip On, Redis On.
