查看: 2161|回复: 0
[招聘] Cadence BJ 招聘信息
发表于 2012-6-11 14:00:08 | 显示全部楼层 |阅读模式
1. Member of consulting staff for RF simulator (Location: BJ)
Job Description
The position is for analog circuit simulation engineer responsible for designing, implementing and maintaining SPICE-like circuit simulation software for use with analog, RF and mixed signal circuit simulators. The engineer will be responsible for leading multiple development efforts through the development process, including writing specifications based on marketing and product requirements, designing and implementing product improvements and fixes, and working with a cross-functional team to ensure the software is tested, integrated and documented. The engineer must be proficient in C/C++ Unix development, and have a thorough knowledge of numerical methods for analog circuit simulation. The engineer must have a proven ability to learn from and work with an engineering and cross-functional team to deliver innovative products in a production environment.
Position Requirements
1.Prior experience in development of Spice or steady-state (harmonic balance, shooting, noise) simulation technologies;
2.Strong understanding of matrix solvers and numeric calculations;
3.Familiarity with Spice or Spectre net list format and usage;
4.Skilled in C++ programming, familiar with development under Linux/Unix
5.Familiarity with Analog, RF or microwave design is a strong plus;
6.Good English communication skill both verbally and writing;
7.Good problem solving skill and team work spirit;
8.Education Requirement: PhD in EE, CS, or related.
If you have interest,PLS send your CV to zhangyl@cadence.com
2. Member of Consulting Staff (Location: BJ)
Position Description
-The position is for analog circuit simulation engineer responsible for designing, implementing and maintaining device compact models in SPICE-like circuit simulation software for use with analog, RF and mixed signal circuit simulators. The engineer will be responsible for leading multiple development efforts through the development process, including writing specifications based on marketing and product requirements, designing and implementing product improvements and fixes, and working with a cross-functional team to ensure the software is tested, integrated and documented. The engineer must be proficient in C/C++ Unix development, and have a thorough knowledge of device physics, device compact models. The engineer must have a proven ability to learn from and work with an engineering and cross-functional team to deliver innovative products in a production environment.
1.Well devices physics, device compact models;
2.Familiar with matrix solver & mathematic calculation;
3.Familiar with Spice, Spectre format & usage;
4.Skilled in C++ programming, familiar with development under Linux/Unix environment;
5.Be familiar with Analog-signal design is a plus;
3. Senior Product Engineer for fast Spice
(Location: BJ)
1.We are looking for a highly motivated individual to join Cadence fast SPICE simulator, XPS, development group. The team is currently focused on developing new technology to greatly improve simulation performance and capacity. As product engineer you will shape our product and contribute to our market success.
2.The key role of product engineer is to debug, to narrow down, and to identify the root reason of issues, as well as to work closely with R&D towards a solution.
3.The product engineering team is the
voice of the customer within the R&D group. It is responsible for the communication between R&D and sales, marketing, application engineering, and customers. The role is to support customer evaluation and new technology roll-out, to debug customer simulation problems, to define specifications for new simulation features and bug fixes, to work together with R&D on implementation and test, to maintain the customer test case suite. Product engineer is also responsible for product documentation, demonstrations and trainings, as well as technical and white papers.
1.Education Requirement: MS or above in analog IC design or related fields;
2.Strong background in circuit design, simulation and verification;
3.3~5 years experience in memory or mixed signal design, including Flash, SRAM, DRAM, data converter, custom digital, power management, etc, is a MUST;
4.Familiar with SPICE and fast SPICE simulation technology is a big plus;
Good command in written and oral English required.
GMT+8, 2025-12-22 05:01 , Processed in 0.027934 second(s), 7 queries , Gzip On, Redis On.
