查看: 1711|回复: 0
[转贴] 谨慎使用云存储
发表于 2012-4-27 16:36:45 | 显示全部楼层 |阅读模式
今天测试了一下Google Drive,也想起了Google那个广受辩护的稳私新政,于是决定研究一下Google Drive的。因为总有狗粉认为Google是Never being evil的,所以你可以把下面的Google换成人人再看,应该会好一些。
Link: [url]http://www.Google.com/policies/terms/[/url]
Your Content in our Services
Some of our Services allow you to submit content. You retain ownership of any intellectual property rights that you hold in that content. In short, what belongs to you stays yours. (你的知识版权在你上传后还是你的,这个是最基本的)
When you upload or otherwise submit content to our Services, you give Google (and those we work with) a worldwide license to use, host, store, reproduce, modify, create derivative works (such as those resulting from translations, adaptations or other changes we make so that your content works better with our Services), communicate, publish, publicly perform, publicly display and distribute such content. The rights you grant in this license are for the limited purpose of operating, promoting, and improving our Services, and to develop new ones. This license continues even if you stop using our Services (for example, for a business listing you have added to Google Maps). Some Services may offer you ways to access and remove content that has been provided to that Service. Also, in some of our Services, there are terms or settings that narrow the scope of our use of the content submitted in those Services. Make sure you have the necessary rights to grant us this license for any content that you submit to our Services. (一但你上传了,你给了Google(及相关人员)全球范围的许可,可以使用,集合,存储,复制,修改,衍生(比如翻译,改编及其它我们认为需要的使你的内容更合乎我们服务的修改),交流,公开,公开传播,公开展示与分发的些内容的权利。你授予的这些权利允许我们将其用于且仅用于操作、优化和提升我们的服务,以及开发新的服务。这项权利在你停止使用我们的服务后仍然持续。有的服务允许你访问和删除你上传的内容。有的服务允许你限制我们对你上传内容的使用。你确实你给予了我们适当的许可)
平心而论,这些主要是为了获得你的许可,使他们可以压缩啦、复制啦来存储你的文件,用更通俗的说法大概就是,你在银行存了10张100元的钞票,银行不认为他们就是10张应该放在保险箱里的纸,而是真正的1000元钱。他们可以拿来投资、套利,从中获得利润。最终只要他们保证能把这1000元钱在你需要的时候给你就可以了。并不要求还是你给他们的那10张纸。
但在某些方面Google走的太远了。上传后Google自动获得了公开传播与展示的权利。换句话说,他拥有的不仅仅是作为一个文件这个东西本身,同样的,他获得了你对其中内容的使用与展示的授权。
举个极端的例子。你是加菲猫这个卡通形象的持有者,你身边有一台chrome os。有一天你灵感大发用这台电脑画了几只新的加菲的形象,自动保存在Google Drive里了。第二天,你发现Google把自己的doodle改成了你刚画的加菲猫,还进行了修改。根据这个你允许了的条例,他们是可以这样做的,没有问题。于是你愤怒地把你画的加菲猫删掉了。但根据这份你允许了的条例,他们仍然可以继续展示使用下去。
这个本来的目的应该是为了避免可能的法律纠纷。比如说你和你的朋友通过Google Drive分享了一个文件,但是可能任何一个拿到这个link的人都可以获得这个文件。这种情况下Google是没有责任的,而应该是你负责保管好那个 link。就像信用卡公司突然对你说,你的卡被别人刷了。那个人提供了正确的卡号和密码,所以责任是你的,因为你没保管好卡号和密码。甚至你说我三个月前已经把这个帐户注销了啊也没有。这种看起来都有些荒谬的事情正是这个条例所希望避免的。
再有就是他们有权使用你上传的内容进行优化升级。比如说你个人拥有windows的版权。有一天你不小心把windows的源代码上传到了Google,当时Google还建立在dos系统上。 Google发现了你的源代码的价值。根据这个协议,他们获得了使用权,因而可以修改编译你的源代码,把Google内所有的dos机都更新换代成了 windows。他们获得的是永久的使用权,所以不管你是删了源码还是怎么样,他们都可以继续免费使用你写的windows。当然windows这个有点扯,换成你是一个phd不小心上传了自己的实验数据被Google的实验室拿走了优化了自己的引擎还拿了图灵奖,这也是有可能的。
于是这就产生了Google这个协议与平时我们使用的银行的区别。银行也是获得了对你的钱进行任意使用的权利。他们并不把你的钱放进保险箱,而是拿去投资放贷。但是,钱对于所有人都是同质的。你的1000元和他的1000元交换后除了编号变了没有任何区别。可文件就不一样了,交换后双方所获得的东西就不同了。更何况文件和钱不一样,你把钞票收回来,银行就没有你的钱了,你的钱完全是你的钱。可文件不同,即使你删了,Google仍然有权动用你的备份。比如说你拍了一张非常漂亮的图,被一个杂志社看中了,准备买下来跟你签一个排他性的协议。可是因为你用了Google Drive备份过你的照片,在法理上你已经失去了这个图的独有权,所以你是没资格签排他性协议的,你还要去找Google处理这样的法律事务。
而且更可怕的是一个短句,those we work with,无论是什么人和机构,只有Google说我们有合作我们签了协议,那对方就能使用你的数据了。同样的,你拍的图本来打算卖5000块,但杂志社可能跟Google有协议,花了50块就拿去用了,你也就别想卖掉了。
因此,Google的手伸的太长了。这个事情在前段时间Google改变自己的隐私条例时就已经很明显了,可以让所有的Google的服务使用你的东西。当时虽然是轻描淡写,但事实上是非常大的改变。而且这种授权是永久性的,这实在是有点可怕。
所以,我建议,你所有的实验数据啦、讲稿啦、论文啦,请不要放在Google Drive上,事实上连gmail都不是太好。如果一定要放,请加密。尽管Google在法理上有权解密你的文件并使用,但估计这点是很困难的。
再顺便看一下dropbox和skyDrive的规定
Dropbox: https://www.dropbox.com/terms
By using our Services you provide us with information, files, and folders that you submit to Dropbox (together, “your stuff”). You retain full ownership to your stuff. We don’t claim any ownership to any of it. These Terms do not grant us any rights to your stuff or intellectual property except for the limited rights that are needed to run the Services, as explained below. (你的东西仍然是你的,和Google一样)
We may need your permission to do things you ask us to do with your stuff, for example, hosting your files, or sharing them at your direction. This includes product features visible to you, for example, image thumbnails or document previews. It also includes design choices we make to technically administer our Services, for example, how we redundantly backup data to keep it safe. You give us the permissions we need to do those things solely to provide the Services. This permission also extends to trusted third parties we work with to provide the Services, for example Amazon, which provides our storage space (again, only to provide the Services). (我们需要获得你的许可来处理你的文件,比如存储或者在你的要求下分享它们。这包括你可见的部分(比如图像缩略图、文档预览),也包括我们选则的提供服务的技术手段(比如 我们怎么备份)。这个授权仅仅是我们这一项服务可用(dropbox的云存储),并可能扩展至提供服务的第三方(比如提供硬件存储空间的Amazon)。但是,仅仅适用于这个服务本身)
也就是说,就算是dropbox将来成了网络上最大的唱片公司,只要你没同意那些稀奇古怪的新协议,就这份协议来看,你存储在dropbox的你的原创歌曲他们是不能直接拿去用的。而Google在法理上是可以这样用的。而且,dropbox也没有权利分布、展示你的文件,简单说就是他们只能把文件传输到你link的设备,或者你能过用户名密码上网下载你的文件,或者你授权给别人获得你的文件,除此之外都是非法的。当然上面说的保护自己的link仍然是一样的。因此,就这段协议来说,用dropbox保存备份你的实验数据什么的是安全的。但是我没有阅读整个完整的协议,所以最安全的作法还是不要用dropbox备份你的数据。
再看看skyDrive
http://windows.microsoft.com/en-US/windows-live/microsoft-service-agreement?SignedIn=1
5. Your content
Except for material that we license to you, we don't claim ownership of the content you provide on the service. Your content remains your content. We also don't control, verify, or endorse the content that you and others make available on the service.(你的东西还是你的)
You control who may access your content. If you share content in public areas of the service or in shared areas available to others you've chosen, then you agree that anyone you've shared content with may use that content. When you give others access to your content on the service, you grant them free, nonexclusive permission to use, reproduce, distribute, display, transmit, and communicate to the public the content solely in connection with the service and other products and services made available by Microsoft. If you don't want others to have those rights, don't use the service to share your content. (你控制谁能访问你的文件。如果你向公众分享你的文件,你同意任何人可以看到它并任意使用它。如果你不希望这样,请不要分享你的文件)(注:就是说把你的文件放到一个叫public的文件夹,这个还是很好理解的)
You understand that Microsoft may need, and you hereby grant Microsoft the right, to use, modify, adapt, reproduce, distribute, and display content posted on the service solely to the extent necessary to provide the service.(你理解并授权我们对你文件可能的使用、修改、调整、复制、分发、展示内容、在这个服务上发布的权利,但这能且只能用于这个服务本身)
Please respect the rights of artists, inventors, and creators. Content may be protected by copyright. People appearing in content may have a right to control the use of their image. If you share content on the service in a way that infringes others' copyrights, other intellectual property rights, or privacy rights, you're breaching this contract. You represent and warrant that you have all the rights necessary for you to grant the rights in this section and the use of the content doesn't violate any law. We won't pay you for your content. We may refuse to publish your content for any or no reason. We may remove your content from the service at any time if you breach this contract or if we cancel or suspend the service.(如果你的文件侵权了,我们可能会搞掉它)
You're responsible for backing up the data that you store on the service. If your service is suspended or canceled, we may permanently delete your data from our servers. We have no obligation to return data to you after the service is suspended or canceled. If data is stored with an expiration date, we may also delete the data as of that date. Data that is deleted may be irretrievable.(如果我们挂了,我们不会因为你的文件丢失而赔偿。如果你的文件超过一定期限,我们可能会删了它)
在授权方面msft和dropbox类似,仍然是你的东西只能用于skyDrive本身。我们可能会复制备份你的文件,压缩修改它们,但这些东西只用于网络存储和在你授权下的分享行为,其它的我们是不能用的。
但ms有一点不好,就是如果你长时间不用他们有权删除你的文件。想必当年25m的hotmail因为删邮件坑了你们很多人吧。我的邮箱就被清空了,让我骂了他们很久。
值得注意的是如果你上传的东西侵权了,msft知道了有权直接删了它。这个还是要注意的。不过,就我理解,用skyDrive保存你的实验数据、论文、照片什么的是没有问题的,你仍然有排它性的使用权。
PS:我觉得问题的核心在于你上传的文件服务提供商是把它看作某个大小的无差别的数据,还是一个完整的有意义的内容。按理说他们是没有权利动你的东西的内容的。但所有的协议都让他们动了。
PS2:以上都是免费个人用户协议。商业用户和付费用户的没看,不过我觉得个人付费用户的内容应该是一样的,商业用户,尤其是大客户,会单独签合同,所以也没什么可多说的。
PS3:这篇文章的版权,根据人人网的说法,已经是人人网所有了~
GMT+8, 2025-11-9 03:02 , Processed in 0.018199 second(s), 6 queries , Gzip On, Redis On.
