查看: 2213|回复: 0
[原创] The Maintenance of Dental Scaler
发表于 2012-3-19 15:31:26 | 显示全部楼层 |阅读模式
The ultrasonic scaler is a sophisticatedmedical equipment. A correct operation and a regular maintenance and repair is an effectiveway to make it in good working condition to reduce any malfunction and avoidthe failure to extend it’s use life. Now we are going to describe the precautionsand the maintenance of the ultrasonic scaler.
Duringthe process of cleaning, the operating head must have sprayed and do not forceexcessive pressure to the contact place. Meanwhile the operating head should bechanged frequently to prevent the heat damage the generator and transducer.
Theworking head and transducer of the ultrasonic scaler should not be boiled andsoaked in disinfection. Instead of not damaging the transducer it should beplaced in a disinfecting instrument.
Usually the intake unit ofultrasonic scaler is connected with water,so in order not to bepluged by the rust we should clean the nets within the device at least 2 or 3times a week.
About Air Polisher. Alcohol should be mosthelped to cleaning the outside of the air polisher. Do not use oil or any protective agents to lubricating it. Plus do notput the Air Polisher or any powder containers into the ultrasonic scaler.
Thewaterway congestion has been a vexing problem.A lot of doctors don’t know howto fix it because the waterway is not straight thus a iron wire is notfeasible.
When we need to indisfect the air polisher we could dothat with a chemical sanitizer. Please do not placeit in the disinfectant. The contaciners and handles need to be separated forhigh-temperature sterilization or high-temperature sterilization. At the sametime there aren’t any traces of powder left there after a careful cleaning.Then we should remove the air polisher
outfrom the sterilization equipment immediately. Otherwise there might be a dangerof contact corrosion. Before the powder container is connected all componentsand air channels must be absolutely dry.
It’s a basic work at any oral outpatient treatment.But many doctors ignore its importance. For the benifit and health we should beserious and responsible with every knowledge about tooth brushing. Looking foemore information on www.izidental.com
GMT+8, 2025-12-20 01:15 , Processed in 0.019705 second(s), 7 queries , Gzip On, Redis On.
