楼主: Synopsys-IC
ic6141与ic5141共存设置问题
发表于 2012-8-31 23:07:31 | 显示全部楼层
回复 1# Synopsys-IC
我的ic614和ic610是共存的,只需要每次在cmd下输入'ic614'或'ic610'就可以转换,给个bashrc的例子吧:
alias   ic614='export CADENCE=ic614;
   export CDS_ROOT=/home/eda/ic614;
  export CDSHOME=/home/eda/ic614;
  export CDS_INST_DIR=/home/eda/ic614;
  export OA_HOME=/home/eda/ic614/oa_v22.04.054;
  export CDSDIR=$CDSHOME/tools/dfII;
  export PATH=`echo $PATH | sed s/ic610/ic614/g`;
  export LM_LICENSE_FILE=`echo $LM_LICENSE_FILE | sed s/ic610/ic614/g`;
  export LD_LIBRARY_PATH=`echo $LD_LIBRARY_PATH | sed s/ic610/ic614/g`;
  export CDS_LIC_FILE=$CDS_ROOT/share/license/license.dat:/home/eda/MMSIM10/share/license/license.dat;'
alias    ic610='export CADENCE=ic610;
   export CDS_ROOT=/home/eda/ic610;
  export CDSHOME=/home/eda/ic610;
  export CDS_INST_DIR=/home/eda/ic610;
  export OA_HOME=/home/eda/ic610/OA;
  export PATH=`echo $PATH | sed s/ic614/ic610/g`;
  export LM_LICENSE_FILE=`echo $LM_LICENSE_FILE | sed s/ic614/ic610/g`;
  export LD_LIBRARY_PATH=`echo $LD_LIBRARY_PATH | sed s/ic614/ic610/g`;
  export CDS_LIC_FILE=5280@dingdang-laptop:/home/eda/MMSIM10/share/license/license.dat;'
发表于 2012-11-19 21:23:46 | 显示全部楼层
高手好多!
发表于 2014-8-19 00:34:54 | 显示全部楼层
同一个shell估计不行
 楼主| 发表于 2014-11-21 16:11:36 | 显示全部楼层
自顶!重归论坛,有问题私信我!
发表于 2018-2-7 19:11:09 | 显示全部楼层
learning~~~
发表于 2018-2-8 11:12:08 | 显示全部楼层
thanks for sharing
发表于 2018-2-8 12:32:25 | 显示全部楼层
#!/bin/csh
echo " 1. ic5141 : "$old
echo " 2. ic6141 : "$new
echo -n " select 1 or 2 : "
set sl = $<
while ($sl != 1 && $sl != 2 )
  echo ""
  echo " input error , select again"
  echo ""
  set sl = $<
end
if ($sl == 1) then
  ic6141 所有的环境设定
else
   ic5141 所有的环境设定
endif
发表于 2018-2-9 03:12:11 | 显示全部楼层
Interesting
发表于 2018-2-11 18:07:24 | 显示全部楼层
谢谢分享!但我还是不大懂,希望楼主能把最好的破解方法贴出来!
发表于 2019-8-13 20:20:16 | 显示全部楼层
高手
GMT+8, 2025-12-29 00:01 , Processed in 0.018790 second(s), 3 queries , Gzip On, Redis On.
