楼主: alexbaby
[2011-12-17][软件][CADENCE][VSDE4.1ISR2009 x86_64]
发表于 2012-7-11 21:50:31 | 显示全部楼层
回复 1# alexbaby
Is SDE included in IC615 or a separate program? Looks like IC615 LX  and GLX are VSDE now, is it true? If SDE is a separate program is it compatible with IC615  64 bit?  Thanks in advance.
SDE的是IC615或一个单独的程序?如IC615 LX和GLX看起来是VSDE的现在,是真的吗?如果SDE是一个单独的程序,它是与IC61564位兼容吗?感谢在前进。
 楼主| 发表于 2012-7-12 09:43:35 | 显示全部楼层
回复 11# AcoAco
I'm not so sure if VSDE is put in IC 6.15, but there must be another framework like VSDE in IC 6.15 to do the same like VSDE. You could check and try IC 6.15. FYI.
发表于 2013-4-23 19:29:01 | 显示全部楼层
thanx
发表于 2013-4-23 23:56:07 | 显示全部楼层
good download thx you
发表于 2013-4-25 00:58:55 | 显示全部楼层
thanx
GMT+8, 2025-12-26 07:24 , Processed in 0.018776 second(s), 4 queries , Gzip On, Redis On.
