查看: 14044|回复: 38
[原创] isscc2011 LED Driver
发表于 2011-12-1 10:47:15 | 显示全部楼层 |阅读模式
A 1.2-A Buck-Boost LED Driver With On-Chip Error Averaged SenseFET-Based Current Sensing Technique
Rao, S.;   Khan, Q.;   Bang, S.;   Swank, D.;   Rao, A.;   McIntyre, W.;   Hanumolu, P. K.;
School of EECS, Oregon State University, Corvallis,
This paper appears in: Solid-State Circuits, IEEE Journal of
Issue Date: Dec. 2011
Volume: 46 Issue:12
On page(s): 2772 - 2783
ISSN: 0018-9200
Digital Object Identifier: 10.1109/JSSC.2011.2162921
Date of Publication: 01 September 2011
Date of Current Version: 21 November 2011
Sponsored by: IEEE Solid-State Circuits Society
[size=1.085em]ABSTRACT
This paper presents circuit techniques to improve the efficiency of high-current LED drivers. An error-averaged, senseFET-based current sensing technique is used to regulate the LED current accurately. Because the proposed scheme eliminates the series current-regulation element present in all conventional LED drivers, it greatly improves efficiency and reduces cost. The converter operates in three different operating modes, namely buck, buck-boost, and boost modes, and achieves high efficiency over the entire Li-Ion battery range (3–5.5 V). Fabricated in 0.5-$mu{hbox {m}}$ CMOS process, the prototype occupies an active area of 5 ${hbox {mm}}^{2}$ . At 1.2-A LED current, the driver achieves an efficiency improvement of over 13% compared to current-regulation-element-based LED drivers. Measured LED current accuracy is better than 2.8% over the entire range of the battery and its standard deviation measured across seven devices is less than 1.6%. The peak efficiencies are 90.7% and 86% at 600- and 1200-mA currents, respectively.
附件包括: isscc2011,isscc2011 ppt, jssc2011 LED Driver.rar (3.35 MB , 下载次数: 405 )
发表于 2011-12-6 10:42:49 | 显示全部楼层
谢谢分享。
发表于 2011-12-6 11:01:32 | 显示全部楼层
发表于 2011-12-8 22:08:57 | 显示全部楼层
3xxxxxxxxxxxxxxxx
发表于 2011-12-17 00:25:43 | 显示全部楼层
thanks!!
发表于 2011-12-17 21:27:02 | 显示全部楼层
shenme dongxi
发表于 2011-12-20 23:12:18 | 显示全部楼层
回复 1# princesunny
thanks for your sharing
发表于 2011-12-21 11:15:44 | 显示全部楼层
发表于 2011-12-22 11:23:49 | 显示全部楼层
看看怎么样?
发表于 2012-2-2 11:00:57 | 显示全部楼层
谢谢楼主分享~
GMT+8, 2025-9-16 05:25 , Processed in 0.022533 second(s), 6 queries , Gzip On, Redis On.
