楼主: bingled
spyglass4.4.0破解(32bit&64bit)
发表于 2015-1-16 10:24:18 | 显示全部楼层
回复 1# bingled
基本能用,希望不会出现其他问题多谢
发表于 2015-3-3 09:25:33 | 显示全部楼层
多谢 ,找了好长时间
发表于 2015-4-6 20:03:27 | 显示全部楼层
正好需要啊。能有5.2以上版本的破解吗
发表于 2015-4-6 22:01:54 | 显示全部楼层
终于下完了,信元大损啊~~~
发表于 2015-4-6 22:39:45 | 显示全部楼层
还是不行,怎么解决的?
spyglass: INTERNAL-ERROR, the VALUE OF `$SPYGLASS_HOME' (an internal variable) was not intuited correctly.
spyglass:                 The value guessed was: `SPYGLASS_HOME=/home/APPL/atrenta/SpyGlass-4.4.0/SPYGLASS_HOME'
spyglass: INTERNAL-ERROR, the Perl 5 installation within `$SPYGLASS_HOME' could not be validated.
spyglass:                 A perl installation was expected at: `/home/APPL/atrenta/SpyGlass-4.4.0/SPYGLASS_HOME/lib/multi-perl'
spyglass:                 either `$SPYGLASS_HOME' was guessed incorrectly or the installation is corrupted.
spyglass: NOTE, the caller's environment variable `$SPYGLASS_HOME' was ignored in this process.
发表于 2015-4-14 12:15:08 | 显示全部楼层
xeixei
发表于 2015-4-16 15:11:52 | 显示全部楼层
有没有相应的软件安装包下载啊
发表于 2015-4-16 21:31:34 | 显示全部楼层
还是没人能解答吗?用不了啊
发表于 2015-4-19 02:13:12 | 显示全部楼层
Still having problems running the GOALs ...
发表于 2015-4-19 10:11:55 | 显示全部楼层
回复 1# bingled
   已经收藏
GMT+8, 2025-12-19 06:23 , Processed in 0.018853 second(s), 3 queries , Gzip On, Redis On.
