查看: 2841|回复: 6
[求助] Ansoft Designer help
发表于 2011-6-9 04:40:42 | 显示全部楼层 |阅读模式
hi dears...
we can trusted to the designed structure with Ansoft Designer?
i have designed a leaky wave antenna with CRLH and i want to build it with copper..
is my simulation in ansoft designer reliable ?
发表于 2011-6-9 08:10:32 | 显示全部楼层
可以,现在Designer6中已经有有限元法求解,任何频段都可以做
 楼主| 发表于 2011-6-9 14:58:03 | 显示全部楼层
回复 2# zhangyuan277
you say that i can to build it?becuse my firend said that you should simulate your antenna in HFSS..
i want to know ansoft designeer is sufficent or i should again simulate it in hfss?
发表于 2011-6-12 10:03:40 | 显示全部楼层
回复 3# molteza
    在Designer作天线仿真速度比HFSS快,毕竟矩量法求解嘛,可以得到近似参数,但就仿真的精度而言,最终还是要在HFSS里建模优化的,如果你仿真天线阵的话,当然又是另外一回事了,呵
发表于 2012-8-7 17:08:12 | 显示全部楼层
冷静围观!
发表于 2012-11-29 17:35:39 | 显示全部楼层
了解一下。
发表于 2016-3-15 15:50:27 | 显示全部楼层
thanks for share!
GMT+8, 2025-12-24 08:43 , Processed in 0.020402 second(s), 6 queries , Gzip On, Redis On.
