查看: 6536|回复: 16
[资料] The Industrial Electronics Handbook, 2nd Edition
发表于 2011-6-6 09:16:26 | 显示全部楼层 |阅读模式
Book Description
The field of industrial electronics covers a plethora of problems which must be solved in industrial practice. Electronic systems control many processes that begin with the control of relatively simple devices like electric motors, through more complicated devices such as robots, to the control of entire fabrication processes.An industrial electronics engineer works with many physical phenomena as well as the sensors which are used to measure them. Thus the knowledge required by this type of engineer is not only traditional electronics but also specialized electronics, such as those required for high power applications. The importance of electronic circuits extends well beyond their use as a final product in that they are also important building blocks in large systems. Therefore, the industrial electronics engineer must also possess knowledge of the areas of control and mechatronics. Since most fabrication processes are relatively complex, there is an inherent requirement for the use of communication systems that not only link the various elements of the industrial process, but are tailor-made for the specific industrial environment.
Finally, the efficient control and supervision of factories requires the application of intelligent systems in a hierarchical structure to address the needs of all components employed in the production process. This latter need is accomplished through the use of intelligent systems such as neural networks, fuzzy systems or evolutionary methods.  The Industrial Electronics Handbook, now in its second edition, addresses all these issues in five separate volumes which can be purchased individually or as a set: Fundamentals of Industrial Electronics, Industrial Communication Systems, Intelligent Systems, Power Electronics and Motor Drives, and Control and Mechatronics.
Book Details
Hardcover: 4052 pages
Publisher: CRC Press; 2nd Edition (March 2011)
Author:Bogdan M. Wilamowski, J. david Irwin
Language: English
ISBN-10: 9781439802892
ISBN-13: 978-1439802892
File Size: 12.0 MiB
CRC.Press.The.Industrial.Electronics.Handbook.2nd.Edition.Mar.2011.pdf (12.02 MB , 下载次数: 555 )
发表于 2011-6-7 14:30:54 | 显示全部楼层
好资料,就是价钱太贵了!
发表于 2011-6-7 18:16:00 | 显示全部楼层
发表于 2011-6-8 15:21:35 | 显示全部楼层
相当不错,经典收藏
发表于 2011-6-8 15:22:50 | 显示全部楼层
dwonalod complete...感謝分享
发表于 2011-6-30 09:56:21 | 显示全部楼层
Thanks.
发表于 2011-7-19 14:14:49 | 显示全部楼层
回复 1# ArchAngel
发表于 2012-3-18 04:39:14 | 显示全部楼层
收藏一下,下下来才知道是人工智慧的书,呵呵
发表于 2013-1-12 09:28:47 | 显示全部楼层
看上去很美
发表于 2017-7-18 22:17:51 | 显示全部楼层
这是好书,太厚
GMT+8, 2025-12-14 01:37 , Processed in 0.028297 second(s), 8 queries , Gzip On, Redis On.
