查看: 3198|回复: 5
[资料] Sony ICX204AK datasheet
发表于 2011-4-8 10:55:23 | 显示全部楼层 |阅读模式
  The ICX204AK is a diagonal 6mm (Type 1/3)
interline CCD solid-state image sensor with a square
pixel array and 800K effective pixels. Progressive
scan allows all pixels' signals to be output
independently. Also, the adoption of high frame rate
readout mode supports 60 frames per second. This
chip features an electronic shutter with variable
charge-storage time which makes it possible to
realize full-frame still image without a mechanical
shutter. High resolution and high color reproductivity
are achieved through the use of R, G, B primary color
mosaic filters. Further, high sensitivity and low dark
current are achieved through the adoption of HAD
(Hole-Accumulation Diode) sensors.
  This chip is suitable for applications such as
electronic still cameras, PC input cameras, etc.
发表于 2011-5-8 15:30:57 | 显示全部楼层
thxyou eetop.
发表于 2012-9-27 15:59:59 | 显示全部楼层
謝謝分享!!
发表于 2012-10-4 18:23:58 | 显示全部楼层
回复 1# k621219
    thanks!
发表于 2013-8-18 19:15:51 | 显示全部楼层
表清方案
发表于 2013-9-6 07:28:55 | 显示全部楼层
Great work done.
GMT+8, 2025-9-18 08:58 , Processed in 0.021404 second(s), 7 queries , Gzip On, Redis On.
