楼主: landrokhan
[原创] 用c语言开发单片机与汇编有什么优劣吗?
发表于 2014-8-6 17:12:17 | 显示全部楼层
C is higher level programming language. Development of complex algorithm is easy with c compared to assembly. C makes portable and readable code. Many C compilers produce good optimized code but some time C has its own limitations while accessing CPU registers or special CPU features. In this case assembly can be used.
发表于 2014-8-11 14:47:48 | 显示全部楼层
C语音维护性和可读性较强,移植和继承性也较好。
汇编就是效率会很高,但可移植和集成性不好。维护性不好。尤其是不太使用的平台哦!
发表于 2016-11-26 10:14:03 | 显示全部楼层
C上手快吧,汇编更有效率
发表于 2016-12-3 14:33:41 | 显示全部楼层
汇编效率低啊
发表于 2016-12-6 13:20:51 | 显示全部楼层
用c语言开发单片机与汇编有什么优劣吗
发表于 2018-11-16 13:20:12 | 显示全部楼层
來看看  學習了
GMT+8, 2025-9-17 21:15 , Processed in 0.013356 second(s), 3 queries , Gzip On, Redis On.
