楼主: shiiuen
[2010-12-28][软件][c0vent0r][SEMulator3D][2008][无][原创]
发表于 2013-7-8 15:37:56 | 显示全部楼层
谢谢楼主分享,如何crack?
发表于 2013-9-11 13:30:30 | 显示全部楼层
真不容易啊,找了它很久了
发表于 2014-4-2 00:29:22 | 显示全部楼层
非常感谢
发表于 2014-4-30 22:38:37 | 显示全部楼层
good good
发表于 2014-5-18 16:45:37 | 显示全部楼层
谢谢楼主,找了半天了
发表于 2015-9-9 13:28:58 | 显示全部楼层
回复 10# aloter
HOW TO CRACK ANY SOFTWARE??
In this tutorial you will learn how to crack any type of software protection using
W32Dasm and HIEW.
IDENTIFYING THE PROTECTION:
Run the program, game, etc., (SoftwareX) that you want to crack without the CD in the
CD reader. SoftwareX will not run of course, however, when the error window pops up it
will give you all of the vital information that you need to crack the program, so be sure to
write down what it says.
CRACKING THE PROTECTION:
Now, run Win32Dasm. On the file menu open DISASSEMBLER > OPEN FILE TO
DISASSEMBLE. Select SoftwareX’s executable file in the popup window that will
appear (e.g. SoftwareX.exe). W32Dasm may take several minutes to disassemble the file.
When W32Dasm finishes disassembling the file it will display unrecognizable text; this is
what we want. Click on the String Data References button. Scroll through the String Data
Items until you find SoftwareX’s error message. When you locate it, double click the
error message and then close the window to return to the Win32Dasm text. You will
notice that you have been moved somewhere within the SoftwareX’s check routine; this
is where the error message in generated.
Now comes the difficult part, so be careful. To crack SoftwareX’s protection you must
know the @offset of every call and jump command. Write down every call and jump
@offset number that you see (You have to be sure, that the OPBAR change its used color
to green). You need the number behind the @offset without the “h.”
Now open HIEW, locate SoftwareX’s executable, and press the F4 key. At this point a
popup window will appear with 3 options: Text, Hex, and Decode. Click on “Decode” to
see a list of numbers. Now press the F5 key and enter the number that was extracted using
Win32Dasm. After you have entered the number you will be taken to SoftwareX’s check
routine within HIEW.
If the command that you are taken to is
E92BF9BF74, for example, it means that the command equals 5 bytes. Every 2 digits
equal one byte: E9-2B-F9-BF-74 => 10 digits => 5 bytes. If you understood this then you
can continue.
Press F3 (Edit), this will allow you to edit the 10 digits. Replace the 5 bytes with the
digits 90. In other words, E92BF9BF74 will become 9090909090 (90-90-90-90-90).
After you complete this step press the F10 key to exit.
Congratulations! You just cracked SoftwareX!
Don’t panic if SoftwareX will not run after you finished cracking it. It only means that
something was done incorrectly, or perhaps SoftwareX’s protection technology has been
improved or created after this tutorial. Simply reinstall SoftwareX and start over. If you’re
sure that you completed all steps correctly and the program still will not run, then tough
nuts. Their protection was developed after the writing of this tutorial.
ONE MORE TRICK
Originally Posted by miggittymacdadd
1. Install the software and choose License Type as "Network" while asked.
2. After installation, copy VIZ2007\adlmdll.dll to ...\Autodesk\VIZ2007 and overwrite the original one.
3. Setup Flexlm License Server with the files in the supplied FlexLM directory.
4. Start the inventor, input 2080@your_server_host_name or just point to license.lic while the license is requested.
ONE MORE TRICK!!
Copy \Crack\FlexLM directory to C:\Program Files\Autodesk\
Run "C:\Program Files\Autodesk\FlexLM\lmtools.exe"
Select "Config Services" tab at the top
Click "Browse" on the line "Path to the lmgrd.exe file"
Find the file in C:\Program Files\Autodesk\FlexLM\
Click "Open"
Click "Browse" on the line "Path to the license file"
Click "Open"
In the Path to Debug Log file field
Enter "C:\Program Files\Autodesk\FlexLM\Debug.log"
Select "Use Services" and "Start Server at Power Up"
Click "Save Service"
Click "Yes"
Select "Start/Stop/Reread" tab at the top
Click "Start Server"
Select "File" then click "Exit"
Run Autodesk VIZ 2007
Select "Specify the License File"
Click "Next"
Click "Browse"
Click "Open"
Click "Next"
Click "Finish"
If the License File can't be found rerun "C:\Program Files\Autodesk\FlexLM\lmtools.exe"
Click "Stop Server"
and try running Autodesk VIZ 2007 again
credits - rani tha
Posted by Mohit Agrawalat 1:21 PM
Labels:
cracking,
key generator,
software cracking
发表于 2015-11-5 00:05:22 | 显示全部楼层
sad sa
发表于 2015-11-5 00:06:29 | 显示全部楼层
d as das
发表于 2015-11-5 00:07:07 | 显示全部楼层
a sd sad
发表于 2015-11-5 00:07:44 | 显示全部楼层
as d as
GMT+8, 2025-12-17 01:17 , Processed in 0.022130 second(s), 3 queries , Gzip On, Redis On.
