查看: 6936|回复: 2
VMware(6.0)+RHEL(AS4)+Cadence(IC5141)+Calibre(200801)安装文档
发表于 2010-12-23 23:41:57 | 显示全部楼层 |阅读模式
绝对原创,欢迎交流!1年前的心血。 VMware(6.0) RHEL(AS4) Cadence(IC5141) Calibre(200801)安装文档.zip (1.09 MB , 下载次数: 846 )
发表于 2010-12-24 20:15:30 | 显示全部楼层
[xue@localhost root]$ Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
*ERROR* X Window Display Initialization failure
*WARNING* X Window Display Initialization failure
  安装的完成了以后运行 icfb& 就出现这些情况  这个怎么解决?
发表于 2010-12-24 21:41:01 | 显示全部楼层
/home/eda/mentor/ixl_cal_2005.1_10.20/pkgs/icv/pvt/support edOS: line 35: uname: command not found
/home/eda/mentor/ixl_cal_2005.1_10.20/pkgs/icv/pvt/supportedOS: line 36: uname: command not found
/home/eda/mentor/ixl_cal_2005.1_10.20/pkgs/icv/pvt/supportedOS: line 37: uname: command not found
/home/eda/mentor/ixl_cal_2005.1_10.20/pkgs/icv/pvt/supportedOS: line 38: uname: command not found
/home/eda/mentor/ixl_cal_2005.1_10.20/pkgs/icv/pvt/set_mgc_env_ic: line 47: expr : command not found
/home/eda/mentor/ixl_cal_2005.1_10.20/bin/calibre: line 36: uname: command not f ound
/home/eda/mentor/ixl_cal_2005.1_10.20/bin/calibre: line 37: uname: command not f ound
/home/eda/mentor/ixl_cal_2005.1_10.20/bin/calibre: line 38: uname: command not f ound
/home/eda/mentor/ixl_cal_2005.1_10.20/bin/calibre: line 40: grep: command not fo und
刚才上面那个问题是解决了   但是现在安装calibre的时候运行 calibre -gui&的时候又出现这个问题 请大侠帮忙一下  万分感谢!!!!!!
GMT+8, 2025-12-19 20:34 , Processed in 0.047327 second(s), 7 queries , Gzip On, Redis On.
