查看: 2960|回复: 3
[求助] HV process without npn, how can i get a bandgap?
发表于 2010-8-13 15:43:44 | 显示全部楼层 |阅读模式
Hi all:
I am doing a project, 32v hv process without npn transistor, just have 12v npn transistor, how can i generator a bandgap voltage?
Vbe/R current can be got, but other circuitry?????
Thank you help....................
发表于 2010-8-19 22:25:46 | 显示全部楼层
既然是32V的工艺,NPN管达到32V,总有其它有源器件可以达到32V的了,没必要所有器件都使用32V器件。
发表于 2010-8-20 12:35:12 | 显示全部楼层
the 12v npn transistor can be used directly in you design, I think not all circuit using 32v power i.e. bandgap reference.
发表于 2011-5-25 15:30:56 | 显示全部楼层
thanks very much!
GMT+8, 2025-12-22 02:12 , Processed in 0.018996 second(s), 5 queries , Gzip On, Redis On.
