查看: 3176|回复: 6
上海著名外企Atheros招聘! Physical Designer
发表于 2010-8-11 14:13:23 | 显示全部楼层 |阅读模式
If you are interesed with this position, please send your resume to noagain#hotmail.com. Thank
you. Good luck!!
New Grads recruiting for physical design engineer
QUALIFICATION (DETAIL):
Education:
BSEE or MSEE
Experience:
1. Knowledge of any part of the process from netlist handoff to tapeout is a MUST:
Floorplanning
Power planning and signoff
Placement, CTS and routing
SI effect analysis and fixing
Physical verification
2. Hands-on experience on above items is preferred.
3. Scripts development in Perl and TCL
DESCRIPTION OF FUNCTION & RESPONSIBILITY:
1. Implement APR from netlist to gds to close timing and routing
2. Build high efficient PG mesh to meet IR-drop and EM requirements
3. Fix SI effect
4. Perform ECO and metal spin
5. Support die size estimation
6. Develop utilities/scripts to improve design flow
Physical design engineer
Education:
BSEE with 2+ years of related experience, MSEE with 1+ years of related experience
Experience:
1. Hands-on experience of any part of the process from netlist handoff to tapeout:
Floorplanning
2. Physical verification is a MUST
3. Fix SI effect
 楼主| 发表于 2010-8-11 14:29:45 | 显示全部楼层
support!
 楼主| 发表于 2010-8-11 16:37:18 | 显示全部楼层
up up!
发表于 2010-8-12 07:14:32 | 显示全部楼层
metal spin是指添加metal filler么?
发表于 2010-8-12 21:43:45 | 显示全部楼层
看不懂....
 楼主| 发表于 2010-8-13 11:05:00 | 显示全部楼层
 楼主| 发表于 2010-8-13 11:06:06 | 显示全部楼层
看不懂....
twfly 发表于 2010-8-12 21:43
什么地方不懂?
GMT+8, 2025-12-21 18:34 , Processed in 0.025527 second(s), 7 queries , Gzip On, Redis On.
