查看: 4064|回复: 6
Dual-Port RAM 2048*32 (VHDL ,LEF,LIB ,TLF....)
发表于 2010-8-5 10:12:03 | 显示全部楼层 |阅读模式
Key Features
  • Memory Compiler for Dual Port RAM in 0.35µm CMOS Process (C35/S35)
  • triple metal layout data of memory
  • full read/write capability on each port
  • 65536 bit maximum memory size
  • 8 .. 32 bits per word
  • 128 .. 8192 words per DPRAM
  • Simulation models for 3.3V nominal supply
  • 2 separated or 1 common datain/dataout buses per port
  • tri-state dataout bus
Deliverables
  • Frontend services (available via Internet)
    • CADENCE
      • cell library with symbol, functional, abstract and msps view
      • TLF 3.0 & TLF 4.3 timing data file
      • LEF file for silicon ensemble
      • SDF annotable Verilog model
    • VHDL
      • VITAL95 compliant simulation model
      • TLF timing data file for SDF generation
    • SYNOPSYS
      • cell timing model (interface model)
    • MENTOR
      • Design Architect symbol
      • QSIM II simulation model & black box desription
      • black box desription
  • Backend Services (on order)
    • CADENCE
      • cell library with additional layout view with reduced layout                  data (*)
    • gds2 data
      • reduced layout data in gds2 format (*)
              (*) reduced layout data does not contain the following layers:
    • Diffusion
    • Poly1
    • N+ Implant
    • P+ Implant
    • Contact
memory.tar
570 KB, 下载次数: 90 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-8-5 11:22:53 | 显示全部楼层
thxxxxxxxxxxxxxxx
发表于 2010-8-5 13:27:32 | 显示全部楼层
memory compiler 生成的吗?
这个对别人没有意义。
发表于 2013-11-22 08:49:28 | 显示全部楼层
我看看是什么东西了。
发表于 2016-11-23 21:54:15 | 显示全部楼层
但愿这个能用
发表于 2018-5-23 15:39:06 | 显示全部楼层
thank you
发表于 2019-3-21 14:49:51 | 显示全部楼层
看看,希望不要忽悠我
GMT+8, 2025-12-19 14:03 , Processed in 0.028025 second(s), 7 queries , Gzip On, Redis On.
